High Beam Challenge
Old Jan 26, 2018 | 03:58 AM
Skydivelout's Avatar
Skydivelout
High Beam Challenge
So I jumped in the F350 to go to work this morning and when I switched the headlights on, the high beam symbol dimly illuminated on the dashboard. If you pull the flash to pass the high beams illuminate brightly, if you push the stalk to illuminate high beam they change marginally in brightness. On both occasions the high beam symbol illuminates properly. Haven’t really had a chance to get into investigating it, just wondered if anyone had experienced this before??
Old Jan 26, 2018 | 08:14 AM
JayTheCPA's Avatar
JayTheCPA
Perhaps the multi-function switch is going bad?
Old Jan 26, 2018 | 08:45 AM
Bill Kay's Avatar
Bill Kay
Check to see if the high beam element and low beam element are shorted together at the headlight. Had a Jeep Cherokee that I nearly pulled my last few hairs out on with very similar symptoms and it turned out to be a bad headlamp. It would do fine on dim but the bright indicator on the dash would be faintly lit. About two days worth of chasing wires I figured it out. Didn’t help that I bought a brand new one with the exact same fault as the old one.
Good luck!
Old Jan 26, 2018 | 09:05 AM
ArmyLifer's Avatar
ArmyLifer
Darn, I thought this was going to be a d**k measuring contest, but with headlights.
Old Jan 26, 2018 | 01:36 PM
BillyBob69's Avatar
BillyBob69
You didn't say if you have fogs or if they were on but you could of been seeing the fog lights turning off when you push the stalk forward but they stay lit with flash to pass.
Just a thought.
Old Jan 26, 2018 | 08:59 PM
carltonwebb's Avatar
carltonwebb
Bad ground or possibly an element touching on low beam to another?
Old Jan 27, 2018 | 05:33 AM
Tugly's Avatar
Tugly
There are few components involved. The bulb, the relay, and the connections to/between both.
Old Jan 27, 2018 | 12:24 PM
Skydivelout
Good luck!
Solved, was exactly this! Another solution and why this community is awesome!!!
Old Jan 27, 2018 | 07:09 PM
Bill Kay's Avatar
Bill Kay
I thought your symptoms seemed familiar. I’m serious about buying one off the shelf that was faulty In same way. Makes for some nightmare trouble shooting. I was about to burn the Jeep. Glad you figured it out.
jnmescape2010
Escape & Escape Hybrid
Dec 23, 2014 07:26 AM
oft
Oct 17, 2014 08:46 PM
Brians
Aerostar
Feb 7, 2007 03:04 PM
lon371
1997 - 2003 F150
Jan 30, 2005 11:21 AM
Dj300ford
Aerostar
Dec 13, 2003 02:17 AM
