Hello all, what is a B1352 ignition key in circuit failure? Is this a code that comes up because the key is left on while hooked to ae? I have no issues, just the code. Thanks again
I own a 2002
Ford F-150
Category: Not Selected
Sub-Category: Not Selected
Drive Type: RWD
Sub Model: XLT
Transmission Type: Transmission 4-Automatic(4R70W)
Engine Base: 4.2L - 6Cylinders
My Battery keeps dying. I thought it was Alternator problem, bought a new alternator from fordparts, yet the problem persists . Now what I do is that I remove the battery head when ever I pack the vehicle . I went for diagnostics these were the result:
B1322> LeftFront Door Ajar Switch Circuit Short to Ground.
B1462> Driver's Safety Belt Switch Circuit Failure.
B1371> Interior Courtesy Lamp Relay Circuit Failure.
B1352> Ignition Key in Circuit Failure
B1428> Safety Belt Lamp Circuit Failure.
