Sponsored by: Real Truck
rotunda key code table
Old Aug 10, 2019 | 10:45 AM
bubbasz1's Avatar
bubbasz1
I have a 08 f250 and the ignition switch tumbler is going south. I have a new tumbler which comes in pieces, I have the key code that came with the truck, instructions to properly assemble the tumbler but I'm missing one important piece of information that Ford dose not give you when you purchase the tumble/ switch. You need the cut pattern which you have to look up in the Rotunda key code table using your key code, any chance anybody happens to have one of these?
Old Aug 10, 2019 | 11:47 AM
projectSHO89's Avatar
projectSHO89
Your Ford dealer should have the table, it comes with the key cutter from Rotunda.
Do you have a working key? If so, you can measure it and determine which tumbler goes in which station.
Old Aug 10, 2019 | 12:43 PM
bubbasz1's Avatar
bubbasz1
Thanks for the response, I do have a key and the instructions showing how to measure the key but I was so flabbergasted that I actually had the key code for the truck I really wanted to use the table and put the switch together.
Old Aug 13, 2019 | 04:45 AM
bubbasz1's Avatar
bubbasz1
I ended up measuring my key and assembling the tumbler, no problem, new tumbler is in and operational, no issues.
Fire and Ice
13
Aug 6, 2017 08:01 PM
DirtySCREW
Escape & Escape Hybrid
Jan 5, 2014 10:45 AM
jason6432
1997 - 2003 F150
Dec 28, 2011 12:45 PM
longbowhunter
Mar 7, 2008 05:51 AM
Bcoburn
1997 - 2003 F150
Feb 12, 2007 02:59 PM
