Automatic choke question
Old Mar 12, 2012 | 10:43 AM
Ki-Adi-Mundi's Avatar
Ki-Adi-Mundi
I have a 1978 F-350 with a 400 and a two barrel carb. My automatic choke is not working. There is a place for a wire on the thermostatic but no wire. Where would the other end of the wire connect? The alternator? I can't figure out where it would connect?
Thanks
Old Mar 12, 2012 | 10:46 AM
mikeo0o0o0's Avatar
mikeo0o0o0
The wire goes from the terminal on the automatic choke to the "S" terminal on the alternator, that's the stator.
If you look towards the center of the firewall there should be a plug with two wires going to it. One is white w/ black trace, the other blue. The white/black trace is the wire for your choke, the other goes to the idle stop solenoid on the carb. I've seen quite a few of these unplugged or the pigtail that goes to the choke/solenoid is missing.
Here's a picture from another recent post showing the plug.
Old Mar 12, 2012 | 10:40 PM
fmc400's Avatar
fmc400
MSEE
The electric terminal is only for the assist - it is not the sole mechanism behind what opens the choke. In fact, the hot-air stove has to heat the choke up to a certain temperature before the electric assist even kicks in. If your choke is not opening at all, the missing electric terminal will not account for it.
Take a look at this thread: https://www.ford-trucks.com/forums/8...ml#post6939116
79lownlong
Dec 6, 2014 05:28 PM
GOTH_TRUCKER
24
Sep 4, 2006 08:42 AM
ford390gashog
Electrical Systems/Wiring
Oct 25, 2004 02:50 PM
Dustin_86
Jun 8, 2004 10:19 PM
MTZBoeger
Jan 28, 2004 03:46 PM
