electric choke
Old Oct 24, 2004 | 11:43 PM
ford390gashog's Avatar
ford390gashog
electric choke
i found the white and black wire for the electric choke and traced it into the inside of the cab where does it go and where should it come out of right now there is no wire going to the choke
Old Oct 25, 2004 | 01:06 AM
Torque1st's Avatar
Torque1st
Posting Legend
If it is an OEM carb with an electric choke assist it is wired to the "Stator" terminal on the V-regulator. If it is an aftermarket carb with an electric choke it is wired to the ignition switch to be hot in the "RUN" position.
Old Oct 25, 2004 | 02:50 PM
ford390gashog
thanks it is stock and there is a black and white wire running from the s terminal to inside the cab where does that go
