C6 Issue on a 302
Old Mar 9, 2012 | 06:39 PM
77f100guy's Avatar
77f100guy
C6 Issue on a 302
I have a 302 bolted up to a c6. My problem is this. When I cold start the entire car shakes bad. After it warms up not to much. When you put a load on it holding the break it shakes bad again. I hear kind of a roaring high pitched grinding noise. You give it some gas and it evens out. Around 45 and up theres a very noticeable rotating vibration noise. Ive tried numerous things and not found an answer yet. Replaces the driveshaft with a new one. Still doing it. Motor and trans mounts, still doing it. It continues to get worse, the bad shaking, vibration. Really noticeable whenever your driving and come to a stop. Shakes real bad, sounds horrible. Any ideas? I was told the planetaries are bad from a mechanic, but before I tear this thing down I'd like some opinions. Maybe someone out there has already delt with this. Thanks
Old Mar 18, 2012 | 07:54 PM
quesey's Avatar
quesey
with the car in park the only thing turning is the conveter.so i'd look into the motor.
cowmilker08
Apr 17, 2010 09:46 PM
frank83fire
Jan 10, 2009 05:25 AM
ford390gashog
Jul 6, 2007 08:57 PM
baddboy
Sep 27, 2004 01:36 PM
jasond5150
Jul 27, 2004 02:55 PM
