Terrible Vibration
Old Apr 14, 2010 | 04:48 PM
cowmilker08's Avatar
cowmilker08
Terrible Vibration
Mt truck started vibrating bad under acceleration.
When maintaining speed for a few seconds or deccelerating it goes away.
Put your foot back in it, and it starts vibrating again.
It is in the whole truck, not just the steering wheel.
I thaught that it might be the DMF, but apparently according to Talyn auto trucks have flexplates. Which according to him are wanna-be flywheels.
So will a failing flexplate cause this vibration?
How does a flexplate work?
And what can I do to check if it is bad?
Old Apr 14, 2010 | 06:16 PM
RRranch's Avatar
RRranch
It's probably a miss, not the flexplate. Those usually make a hell of a noise when they break that doesn't go away. Usually.
I would guess one of the top injector o rings letting go under higher pressures.
Old Apr 14, 2010 | 07:12 PM
cowmilker08
Anyone else agree or disagree?
EDIT: I discovered some play in the rear u-joint, but i can't see that causing this bad of a vibration.
I'll fix it and see where I stand then.
Old Apr 14, 2010 | 07:43 PM
427 fordman's Avatar
427 fordman
I doubt its your flexplate. I would fix the ujoint and check the rest real close for sure. You might be surprised, that could very well be it. I would almost bet it is
Old Apr 14, 2010 | 08:26 PM
cowmilker08
Last spring when I changed the filter and it was BLACK, plus I've been having some blue smoke on start-up, so yeah, at the least it sounds good. And hey hopefully I won't have to pull the engine.
My fiance is never going to let me forget that I swore up and down it was the DMF! LOL
Old Apr 15, 2010 | 12:16 PM
rideracelivemx7's Avatar
rideracelivemx7
screw it, yank er out and go big or go home! LOL
Old Apr 15, 2010 | 12:23 PM
cowmilker08
If only I had the money. LOL. School just takes too much away from me to do all the fun stuff I wish I could.
Will these work:Motorcraft Injector O-Ring Kit (set of 8) 7.3 Power Stroke DI Turbo Diesel '95-'03?
Or are there cheaper places to get Ford Motorcraft o-rings?
Are there aftermarket options that are superior to Motorcraft?
Oh and what's this I here about copper seals or o-rings or something like that?
Old Apr 15, 2010 | 12:28 PM
rideracelivemx7
no! jim refered me to this guy, Ford Powerstroke 7.3 INJECTOR o-ring, seals, oring kits : eBay Motors (item 140394293795 end time Apr-24-10 17:43:04 PDT) i just paid 52$ shipped and there the ones jim used to! so tehre good stuff
Old Apr 15, 2010 | 04:16 PM
RRranch's Avatar
RRranch
Check the pinion for play when you do the u joint. That could do it too. A bad u joint there can cause the pinion bearings to go out.
Old Apr 16, 2010 | 09:32 AM
cowmilker08
Alright thanks for the help!
Also I noticed yesterday that it gets worse as the truck warms up.
Ok. The u-joint has only been out for a couple weeks. last time I checked there was no play in it. Its not very bad. At least not as bad as the superduty that drove by my gf's house last summer that was dragging the rear driveshaft! haha, clanking down the road! He musta had the truck in 4x4.
It finally stopped raining, out to do truck work now!
Old Apr 16, 2010 | 08:36 PM
fordpride's Avatar
fordpride
this is the orings i used from clay at least i know they are new i just don't like eBay but that me Riffraff Diesel: Alliant Injector O-rings
Old Apr 17, 2010 | 08:57 AM
bad12jr's Avatar
bad12jr
Does it do it in all gears or only when u lug it?
My IDI did something similar. I figured it out when i was going through town at about 40mph when it vibrated really bad, heard bang and saw the drive shaft rolling down the road. One of the bearings come apart on the ujoint.
Old Apr 17, 2010 | 09:46 PM
cowmilker08
Well upon replacing the u-joint yesterday (which i must add went flawlessly [didn't even scratch a knuckle] until i went to close the garage door, at which point all hell broke loose. When the pieces were done flying only three wheels held the door on the track.) the vibration ceased. So yay on that.
This is strange to me because i've had u-joints go out on the back of the driveshaft on both of my old 1987's, and they didn't vibrate like this.
But I will still be doing the o-rings soon, but nowe they can wait until i'm out of school and the crops are in the ground.
(Also some of you were concerned a few months ago that my front bumper was out of wack. So today I got her fixed up. A few hits with a sledgehammer and it looks like factory new.)
hivoltj
Jun 11, 2012 05:50 PM
F350 Strait
Jul 2, 2008 01:47 PM
cjf5150
May 2, 2006 12:21 PM
Dyerstown
Mar 19, 2004 09:12 PM
