HPOP Lines...
Old Mar 9, 2012 | 04:01 PM
schlepprock250's Avatar
schlepprock250
HPOP Lines...
Hey guys,I have a question,it's a newb question really but I haven't looked at any other 7.3s close enough to know,but anyway are the factory HPOP lines braided steel lines,I'm getting ready to order some stuff from Clay and wanted to be sure as the ones on my truck are braided...Thanks..Phil
Old Mar 9, 2012 | 04:04 PM
429 f-100's Avatar
429 f-100
the original ones were steel braided the new ones (oem) are not .
Old Mar 9, 2012 | 04:08 PM
schlepprock250
Thanks Wes,just wanted to be sure...
Old Mar 9, 2012 | 04:33 PM
Shake-N-Bake's Avatar
Shake-N-Bake
I wouldn't necessarily get hung up on having braided jackets vs non-braided as long as the hose is correctly rated. If you get braided hoses then you really need to put some sort of protective covering over it so it doesn't destroy everything around it.
From what I can tell, the industry standard hose color for properly rated smooth hoses is blue. Here is an example of a quality hose that works fine for HPOP lines. This particular hose actually has two layers of steel braid jackets with an outer protective layer. I presume the new replacements from Ford are made of similar material. You might want to give Clay a call and see if he knows for sure.
File Type: pdf
Old Mar 9, 2012 | 04:37 PM
schlepprock250
No I'm not hung up on the braided lines,I'm getting ready to order new ones from Clay and just wanted to make sure mine haven't been replaced already...
Old Mar 9, 2012 | 04:41 PM
Shake-N-Bake
Oh, ok. (I must have mis-understood)
I thought you were wondering if the replacement hoses would be of lesser quality since they might not have the outer braided covering.
Old Mar 9, 2012 | 04:48 PM
schlepprock250
It's cool brother,I was just under the hood(haven't had much time for that lately) and was digging around looking at what it's gonna take to do the HPOP line replacement along with rebuilding the fuel bowl,and as long as I've had my truck I have never actually looked at the lines,I bought my truck used and wanted to be sure they hadn't been replaced already...Thanks ....Phil
TexasGuy001
May 19, 2017 03:59 PM
timmyboy76
Feb 26, 2013 07:51 AM
serious_lee
Feb 19, 2012 11:46 PM
JoeBlow
Apr 10, 2003 08:14 AM
William
Jan 22, 2003 07:10 AM
