89 f-150 4" lift springs NEED HELP
I lifted the back of my truck already with some extra lift springs I had laying around. Now it is time to lift the front. I do not want to buy a lift kit since the back is already lifted plus I already have a 4" drop pitman arm.
If I buy a set of 4" lift springs, shocks, and camber adjusters will I need anything else to correctly lift the front of my truck.
Thanks
Thanks
There are 2 different brackets you would have to buy for the ttb, plus the pair of brackets for the radius arms. Every lift company sells their parts seperate I believe, just look it up under their websites. (in no order)
Rough Country
Tough Country
Skyjacker
Superlift
Rancho
BDS
etc etc etc
Rough Country
Tough Country
Skyjacker
Superlift
Rancho
BDS
etc etc etc
You should be able to get the front end lift springs and pivot parts you need from the Broncograveyard.com
http://broncograveyard.com/bronco/c-172-susp-links.html
http://broncograveyard.com/bronco/c-...l-springs.html
http://broncograveyard.com/bronco/b-509-lift-kits.html
roughridn_sob
04-28-2014 07:19 PM
4x4300i6
07-18-2002 01:56 PM
