3G questions
Old Mar 6, 2012 | 12:38 PM
wicat3's Avatar
wicat3
3G questions
Hey guys I got a mark vii electric fan and have been told i need to upgrade to the 3g. After doing some research I see that it is probbly a good idea due to the old alternator being a fire hazzard. My question is I see some 92 trucks came with 3g how would i know if i have one? Also I wanted to know what is the best size alternator for me to use? The 130 is pricey but I also hear its the best one to use. Any info that can be passed my way would be greatly appreciated
Old Mar 6, 2012 | 12:43 PM
subford's Avatar
subford
If it has a plug on the side with 3 wires with 2 of them larger black ones it is a 2G.
If all the wiring is in the back then it is a 3G.
This link will give you more information on it:
http://oldfuelinjection.com/?p=63
Old Mar 6, 2012 | 01:16 PM
wicat3's Avatar
wicat3
thanks for the info
Old Mar 6, 2012 | 01:45 PM
Kemicalburns's Avatar
Kemicalburns
there is a guy over on FSB that sells 160amp 3g alts, wiring and such for a really good price. might check it out.
Old Mar 6, 2012 | 01:49 PM
Big_Al59's Avatar
Big_Al59
My 93 had a 2g, did the conversion last year. Got a 130 amp alt from the junkyard and a harness kit from rjm. Pretty easy swap and my truck is happier when running the winch.
Old Mar 6, 2012 | 02:13 PM
blurangkid's Avatar
blurangkid
I did a 3G upgrade to my 88 f150. Wiring it up was a snap. I had to do a little fabricating to mount the new alt in the stock alt bracket, but wasn't too bad. I got a high output alt (160 amp!) from RJM Injection.
RJM Injection Tech — Alternators
With alt and pulley it came to around $150, which is pretty fair considering it is not a rebuilt and you can choose dif pulleys and clocking.
Old Mar 6, 2012 | 02:54 PM
wicat3's Avatar
wicat3
So what is a good alternator size for running an electric fan? the rjm site has a 160 for $130
Old Mar 6, 2012 | 03:21 PM
blurangkid's Avatar
blurangkid
Anything over stock (65 amp) would do the trick. Just remember the alternator is only as good as the battery its charging. I prefer optima red top, but I am running a plow which constantly drains the battery. I wouldn't expect the electric fan to draw anymore than 100 amps! So as long as you have a sufficient alt with bigger guage charge wire and a good working battery, you should be good...
patjr_45
Mar 15, 2021 06:57 AM
c_silva88
Jan 26, 2013 10:09 AM
mstoned1
Offroad & 4x4
Mar 27, 2005 08:20 PM
joners
1978 - 1996 Big Bronco
Jun 17, 2003 11:07 PM
