i need to know if my 088 ats turbo will work on a 92 if it does the guy that im going to sell it to is going to pay me to instal it. how much work is it to put it on? what are the steps im going to need to do to get it done? and how much should i charge him?
Try the ats website. Sometimes you can download instructions for older products. Otherwise check out Dieselpowermag.com and do a search for "project 300 turbo install" there you should find a very descriptive "picto-essay" on how its done, although they used a newer wastegated system the meat and potatoes of it should be similar.
My dads truck has the 088 on it and it is a 92. Only thing i could see being an issue is if they have different transmissions, at least on the older banks kit the 'Y' pipe is different for auto or manual, or maybe its just non-OD vs. OD.
test fit? haha sorry im not more help, im not even sure how the ats kit is routed so may not be a problem, but the y pipe on the banks (came off a C-6) will not fit my much larger zf-5. If its going on a 4spd truck i wouldnt be too worried. On that note, my dads 92 is the zf5, but like i said im not sure if the crossover pipe is different. Being it came out in '88 (when the OD trannys did) i think it would work on all of em, T-19,Zf5,C6, or E40D
alright thank you haha cant do so much of a test fit just cause the guy is bringing me the truck from out of state thats why im trying to get as much info as possible
