turbo installtion??
Old Sep 15, 2007 | 05:51 PM
808trucken's Avatar
808trucken
turbo installtion??
hey guys i was just wondering if anyone had a write up or knew were i could get information on installing a turbo on our trucks???and if there was any tricks or tips on the installtion thanks alot!!!
Old Sep 15, 2007 | 07:42 PM
jboard's Avatar
jboard
Our trucks already have a turbo unless you want to upgrade it.
--------Jeremy
Old Sep 16, 2007 | 06:16 PM
808trucken's Avatar
808trucken
yes i wanted to up grade my truck to like the beans d66 or the h2 turbo.. but it looked like quit a job and i was just wondering if anyone had a write up on doing that??? thanks alot guys!!!
Old Sep 16, 2007 | 07:21 PM
Suber's Avatar
Suber
There are many here that have changed out their turbo before including myself. I have a list of the tools you need and the procedure to do it when you are ready. If you do a search of the forums you will find many articles on doing the turbo swap.
Old Sep 16, 2007 | 09:57 PM
sbidaho's Avatar
sbidaho
Removing turbocharger
We need to remove the turbocharger in a 96 F-250 to replace the transfer pump. Do you have any ideas?
Old Sep 17, 2007 | 09:05 AM
plowhand's Avatar
plowhand
Playing in the Dirt
Transfer Pump? Do you mean the fuel pump? If so, you can replace the fuel pump without removing the turbo. This thread has a good write up on the fuel pump replacement: https://www.ford-trucks.com/forums/6...fuel-leak.html
Old Sep 17, 2007 | 09:14 AM
tjbeggs's Avatar
tjbeggs
The D66 is a bolt up job. Just use the write Suber said he has. Not too bad a job except for one bolt. But the H2E is a different story. unless you buy a kit ($2500) it is all custom fab work. Pretty much you will need a mock up motor or pull your motor to work it on a stand. the up-pipes and exhaust collector are different as well as the pedestal and oiling. the downpipe flange is also different and the turbo sits at a different height and angle so the whole top of the down pipe will need to be reworked.
