Tranny question
Old Mar 6, 2012 | 02:00 AM
diablodude64's Avatar
diablodude64
Tranny question
So, first day on the road with the 87 6.9 f250 and it runs great but seems like it's redlining before shifting no matter what. If I don't manually shift it into second it won't shift until about 35-45 mph.
The transmission was replaced a few years back apparently.
I have pulled the plug on the modulator and it looks dry and clean so I don't think that's it but I have a spare just in case.
What should I be checking?
Thanks, Kyle
Old Mar 6, 2012 | 07:05 AM
Lazy K's Avatar
Lazy K
I assume that you mean that you pulled the vacuum pipe at the modulator and checked for signs of trans fluid?
I think you will need to get/hire a vacuun gauge. If you look at the drivers side of the fuel injector pump you will see a small vacuum valve (VRV) with two vacuum lines going to it. One line comes straight from the vacuum pump, the other goes down to the vacuum modulator on the trans. With engine at idle you should have around 20in of vacuum at the line from the vacuum pump and 16in+ vacuum at the one going to the trans.
Also you should have a kickdown rod running up from the trans to the throttle linkage at the engine, check that it is connected at both ends.
cabloom300
28
Dec 2, 2014 11:08 AM
82ford302
Jan 20, 2010 04:44 AM
JSKIER24
Oct 9, 2008 02:11 PM
mwk
Nov 18, 2005 08:22 AM
cocaholic
Jan 2, 2001 05:18 PM
