vacuum modulator???
Old Oct 9, 2002 | 08:12 PM
JSKIER24's Avatar
JSKIER24
vacuum modulator???
Would a bad vacuum modulator cause a C6 Trans to start out in second gear not in first gear and wind way out before shifting in to third? It will shift through all of the gears if manually shifted but not automaticly when put in drive.
Jason
Old Oct 9, 2002 | 11:30 PM
JTY's Avatar
JTY
vacuum modulator???
It may.... but it more likely is only part of the problem. One way to check the modulator, is to disconnect the vacuum line from the back of the modulator. If you get ATF on your hands, or even a bit has leaked, then the diaphram is leaking. Which means you're going to need a new vacuum modulator.
Old Oct 10, 2002 | 12:02 AM
Polkat's Avatar
Polkat
vacuum modulator???
Old Oct 7, 2008 | 07:45 PM
magusjinx's Avatar
magusjinx
Could the vacuum pump on a diesel engine be enough to pull the ATF out and deposit it somewhere else?
Old Oct 8, 2008 | 05:08 PM
rclarke's Avatar
rclarke
Start out in 2nd and delayed upshift to 3rd sounds like a stuck governor. Pull the extension housing and check the governor. If its stuck clean it but the only reason for a stuck governor is trash in the oil. Don't be suprised if you need to overhaul it soon.
Old Oct 9, 2008 | 02:11 PM
jk080's Avatar
jk080
Transmission Rebuilder
X2 I agree
Chris Ko
May 13, 2017 10:23 PM
lance65
Jun 24, 2016 09:49 AM
Joets185
Dec 21, 2015 08:20 PM
Dr. Johnson
Nov 14, 2015 08:14 AM
Hybrid455
Aug 31, 2009 07:32 AM
