Haven't found this specific problem in searches, so- recently been throwing codes for all 8 cylinders at once for Glow Plug Circuit, and sometimes it doesn't want to fire when cold. I can clear the codes, and they come right back, key on engine off, without SES coming on, if started, SES lights. Since all 8 come at once, would seem that the GPCM would be a good starting point? I have access to another GPCM to swap out for a test. Top of the engine and connectors are clean, hasn't been wet etc., otherwise runs great. Best test procedure? I have an AE scanner, just getting started with it. 2001 F350 4x4 dually 7.3 auto, CA non-catalyst
Thanks
Hey Gene, good to see ya over here. In case you didn't know, you posted in the 94.5-97 7.3 forum, not the 99-03. I'm not any help otherwise, some of the other guys may be though.
