PERDELS Question...
Old Mar 4, 2012 | 10:33 PM
johnarahill's Avatar
johnarahill
PERDELS Question...
Ran the Change Rotational Velocity test on the old girl today, with the following results:
Cylinder 3: .7
Cylinder 5: 2.5
Cylinder 8: 5.5
The rest were zeroes. I know that it should be expected to show something on 3 and 8, but what about that number on 5? These numbers all drop to zero when any throttle is applied. 8 fails cylinder contribution test, which is fairly normal, as I understand. Do I have a problem? I'm about to replace the valve cover gasket on the passenger side due to a leak, so I'm gonna be in there anyways...
Old Mar 4, 2012 | 10:35 PM
carltonwebb's Avatar
carltonwebb
Which color CPS are u running?
Old Mar 4, 2012 | 11:21 PM
woodnthings's Avatar
woodnthings
2.5 isn't bad. I wouldn't sweat it. I have run these tests on several trucks and a slight variance is normal. Until you get to 5% the CCT will pass. (Unless is it a manual transmission truck)
I suspect you have the grey CPS. That accounts for #8 being high and failing.
Old Mar 5, 2012 | 08:04 AM
johnarahill
I have the dark blue CPS. Picked up a BW yesterday for a spare, I'll probably stick it in and see how it runs...
Old Mar 5, 2012 | 08:48 AM
timmyboy76's Avatar
timmyboy76
What should be the #'s for a manual, Ken?
Old Mar 5, 2012 | 10:36 AM
woodnthings
Manual trucks will fail a CCT when they see over 3%. The difference is the rotating mass of the torque converter on the automatics. For an Auto, the CCT should be taken with the transmission in Drive. I have tried it both ways and don't see a whole lot of difference, but that is what the manual states.
Blue7.3
Australia Chapter
Nov 23, 2014 04:21 PM
ampslw
Apr 18, 2010 10:30 PM
F350-6
106
Apr 17, 2009 10:30 PM
bigrig62
Apr 15, 2009 01:03 PM
O2BNMUDD
Apr 7, 2009 10:16 PM
