need some thoughts
Old Apr 17, 2010 | 11:42 PM
ampslw's Avatar
ampslw
need some thoughts
I ran a cylinder contribution test today and these codes came up. truck was fully warmed up. Not sure how serious it is,
P0269 Cylinder 3 Contribution/Balance Fault
P0284 Cylinder 8 Contribution/Balance Fault
the truck seems to run good
fresh oil last week 15w40 shell rotella
can the valve cover gasketbe reused i would like to re-tork the rockers
truck seems loud at a idel it dose get a lot quiter after a half of an hour of driving but still lots on noise
Old Apr 17, 2010 | 11:45 PM
Waltdog's Avatar
Waltdog
of American machinists
Have you had the CPS recall done? Those codes tend to go with the gray CPS along with noticeable idle change in some trucks. You can try a black CPS and see if it helps
https://www.ford-trucks.com/forums/9...rnational.html
Valve cover gasket is re usable if it is in good condition
Old Apr 17, 2010 | 11:47 PM
CSIPSD's Avatar
CSIPSD
Sounds like you have a great gray CPS... Yay you!
Old Apr 17, 2010 | 11:56 PM
ampslw's Avatar
ampslw
i have never looked to see
i have never looked to see what colour it is
Old Apr 17, 2010 | 11:59 PM
Waltdog's Avatar
Waltdog
If you have been in for the CPS recall, you have the gray CPS
You can plug your VIN in at ford and check for open recalls
Recall Information - Ford
Old Apr 18, 2010 | 10:30 PM
ampslw's Avatar
ampslw
i look to day
i looked today and yes i have the gray cps
