Flex Fuel X ?
Old Mar 9, 2012 | 01:31 PM
  #31
hasteranger's Avatar
hasteranger
Originally Posted by aortizexcursion
Straight from Ford's corporate website:
If you are implying that Ford was hyping this, they weren't. If they were, you would have heard of it before I posted it.
Ford also manufactured the pinto and then said it was safe.
Like I said, dyno or bs.
Old Mar 9, 2012 | 10:06 PM
  #32
aortizexcursion's Avatar
aortizexcursion
The way government regulates business, there's no way Ford would be able to publish blatant lies. And besides, why would they? And that is not a rhetorical question. I want you to answer it.
Old Mar 9, 2012 | 10:49 PM
  #33
hasteranger
wow... seriously??? You need to watch king corn. And beyond that, there are TONS of vehicles that don't dyno consistently with their factory rated power numbers. Look up the mazda RX-8 and the whole debacle with that.
Old Mar 9, 2012 | 11:42 PM
  #34
aortizexcursion
I sure haven't. So I would love to hear what Ford's incentive is to rate an engine higher on ethanol than on gas.
If ethanol did not provide some sort of performance advantage, Ford would not have invested R&D into that "bobcat" engine that was ethanol injected and doled out diesel levels of torque and horsepower. Look it up if you are not familiar with the engine.
Old Mar 10, 2012 | 02:31 AM
  #35
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
You don't gain mileage with E85, you lose it. Each gallon has less power potential than a gallon of gasoline, so for each quantity of ethanol injected you will actually loose power/mileage over gasoline.
speak the truth brother
Originally Posted by Snowseeker
E85 is junk! You don't want anything to do with it!
x1,000,000
Originally Posted by kraylake
It is too bad that domestic biofuels have to be such a political hot topic but regardless of where you find yourself on the issue, US foreign oil imports are dropping partly because of the increased production and use of domestic biofuels.
the stuff is worthless. E85 is a feel good tactic that uses smoke and mirrors to make people feel good about "reducing" our dependancy upon foreign oil
nevermind the negative effects it has on food prices
Misky..you are correct, non-flexfuel designed vehicles have issues with hoses etc. However vehicles designed for for flexfuel have no issues and fwiw those flexfuel designed vehicles can come off the assemly line with NO increased cost to the consumer vs an non flexfuel vehicle.
Today's ethanol price is about $1 a gallon cheaper than gasoline. If we want cheaper fuel, we can have it, we jast have to get past the negitive spin.
1. Per the Ford Maintenance Manual, if you run E-85 in your FFV (Flex Fuel Capable Vehicle), you must change your maintenance intervals to the "EXTREME" interval. That means oil changes and fuel filter changes at 3K miles and.
2. $1 cheaper per gallon, but 4-5 mpg less per gallon. Do the math. E-85 is utterly worthless. If I get bored enough, I'll dig up a spreadsheet I did on this 4 yrs ago when I had my FFV F-150
You don't get more power, you get less. Unless you tune specifically for E85 and install larger injectors and oftentimes a larger diameter fuel line and larger fuel pump, you are not likely to get more power switching to E85. Each gallon of E85 has 20% or so less power than a gallon of gasoline. So a tune that simply maintained stock gasoline power levels would have to inject almost a 25% more fuel. A tune that would take advantage of ethanol's detonation resistance to make more power would be even more. There are no stock fuel systems that I'm aware of that can provide that kind of increase. And moreover, as has already been covered, your mpg will decrease a similar amount. So if you inject the same amount of E85 as you did gasoline on a 100hp engine that got 25 mpg, you would have an 80 hp engine that gets 20 mpg. If you step up your fuel system to get you back to the original 100 hp, you would be down to somewhere around 16 mpg.
I'm firmly with you on the E-85 sucks part...but
The early FFV trucks had entirely different fuel systems (pump and injectors and lines). Later Ford FFV trucks and non FFV trucks all had the same systems. I got lucky with my FFV truck and my blower. The Supercharger required a better fuel pump with higher volume. Luckily the FFV pump can handle the higher fuel demand, whereas the non FFV couldn't.
In addition, the FFV vehicles have dual fuel maps in the PCM. There is the 87 octane map, and the E-85 map. The fuel system has a sensor that detects the ethanol percentage. Once it determines you have E-85 in the tank, the PCM automatically converts to the E-85 maps to utilize the higher energy content. It's been proven repeatedly that vehicles make more power on the E-85.
I know many Mustang guys who are/have converted their fuel systems to E-85. This allows them to run higher boost levels. The higher octane rating of E-85 aids in avoiding detonation at higher boost levels. I sold my KB Boost A-Pump to a gentleman who made almost 100+ extra RWHP just by converting to E-85 and appropriate tuning. It's not completely worthless in that respect I guess
To save assembly line costs, Ford now puts the same components in them all
All I'm sayin is I have YET to hear any benefit or gain from E85. All I ever hear and see is ruined parts and motors, horrible corn mileage, high grocery prices, and still high gas prices (what happened to lower reliance = lower gas prices?).
The cons outweigh the pros. E85 is useless!
The extra maintenance alone kills E-85 as a viable alternative
Add the much lower MPG's and now you're talking about how worthless it really is
Ford rates them higher because they do make more power. No trickery there. It really amounts to a sales tactic IMO....the extra power is there, but nothing worth even bragging about to me
Old Mar 10, 2012 | 09:56 AM
  #36
Snowseeker's Avatar
Snowseeker
All well said! I feel the same way and the public should be fully informed of the cons of E85 and not just the governments idea on the matter.
Old Mar 10, 2012 | 02:11 PM
  #37
aortizexcursion
What Tylus said about performance, and performance only is exactly what I was saying. I originally said that the ONLY advantage of ethanol comes from the POSSIBLE performance figure gains...again, what Tylus said.
Tylus, thank you for not calling me a lier. As for it being a sales tactic, I wouldn't call it that because I have never seen Ford market it. You have to dig for this info in product specification sheets that hardly anyone ever looks at. It is not like they had a $1,000,000 SuperBowl commercial explaining that one spec. If they did, it would be reasonable to call it hyped and in place as a sales tactic. Ford has done zero bragging.
Old Mar 10, 2012 | 03:11 PM
  #38
Snowseeker's Avatar
Snowseeker
If they would get rid of E85 the gas station across the street from me would have a pump open up that they could sell something useful like turbo blue or C16. Or diesel!
Old Mar 10, 2012 | 03:54 PM
  #39
kornfanjoe's Avatar
kornfanjoe
I know for biodiesel you need to upgrade all fuel lines especially rubber because it eats away at the rubber, also you need to upgrade any o rings in your fuel system. Not sure if flex fuel is exactly the same but I'm pretty sure it will have a similar effect. That is why up until recently companies like Ford and Chevy only approved 5% biodiesel(b5) in the trucks anything else voided warranty.
There is lots of information on this over the internet
Mar 19, 2016 02:10 PM
boulderbronco
6.4L Power Stroke Diesel
Jan 27, 2008 08:20 AM
Gr8ride
Jul 1, 2007 02:41 PM
muscletruck7379
Computer Chips & Tuners
Feb 17, 2004 07:48 PM
