starter troubles
Old Mar 4, 2012 | 04:08 PM
77flareside's Avatar
77flareside
starter troubles
Ok guys. after a long battle with getting this fuel tank in, i finally won and got the tank and all the lines in. When i went to crank it though as soon as i turned the key for the aux stuff to come on it started to start and went it fired the starter still would not disengage. What could be causing this. Also it will only start if i shimmy the gear shifter in park or neutral. id love some help because even though this little ranger has given me tons of trouble i still love her. Oh its got the 351m and c6 tranny if that helps any. thanks for the help guys.
Old Mar 4, 2012 | 10:22 PM
77flareside
bump to get it back on the first page.
Old Mar 5, 2012 | 06:59 AM
mark a.'s Avatar
mark a.
Did you try testing the wire that turns on the solinoid ? It shouldn't have any voltage with the key on. If there is nothing there then the solenoid is bad.
Old Mar 5, 2012 | 09:04 AM
bighatchy's Avatar
bighatchy
Definitely the solenoid is sticking. When you replace it, buy a good one. Cheap ones from autozone tend to stick brand new in my experience. Cost me a starter. Plus if you have to move your shifter around for it to start, check your neutral safety switch. It's either going bad or just not engaging properly. My truck the shifter is loose. So you have to pull up on it when starting. Its been that way as long as i can remember. I can remember my dad doing that when I was a little kid
Old Mar 5, 2012 | 10:01 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Make sure you didn't get the wires swapped on "S" and "I" terms of solenoid.
Old Mar 5, 2012 | 02:18 PM
77flareside
swapped in a new solenoid and now she starts up fine. thanks guys.
BigOrange1977
Aug 17, 2014 09:25 AM
fluidp
Jul 8, 2014 08:26 PM
02X72
Oct 29, 2012 04:23 PM
RedDragon
19
Dec 9, 2011 10:32 AM
rich gill
Sep 9, 2010 08:33 PM
