No Crank No Start
Old Jul 8, 2014 | 02:00 PM
fluidp's Avatar
fluidp
No Crank No Start
Hi Guys,,, Just about to head out camping in the bush and the truck wont start..
Thought the camper drained my batts but they are now fully charged and I turn the key and hear a solenoid kicking in but no crank not even trying to crank
Do you think its safe to say the starter is Pooched???
Thanks
Old Jul 8, 2014 | 02:31 PM
madpogue's Avatar
madpogue
Wouldn't assume that yet. Try jumping the relay on the passenger fender (MAKE SURE the tranny is in NEUTRAL (or PARK if an automatic), as this bypasses the safety switch. Even if it doesn't start, see if you hear the solenoid on the starter is clicking.
Old Jul 8, 2014 | 02:47 PM
DIYMechanic's Avatar
DIYMechanic
Do you get a "Wait To Start" light when you turn the key on?
Put the shifter in N and try it too, it could be that the TRS is just out of adjustment.
Old Jul 8, 2014 | 02:54 PM
fluidp's Avatar
fluidp
Hi I pulled the starter and put power directly to the starter motor...motor turned
Then powered the starter motor through the soliniod, the starter gear went out and motor turned.
I will put starter back in truck and try jumping the solenoid on pass fender
Old Jul 8, 2014 | 03:12 PM
madpogue's Avatar
madpogue
That's assuming it's an automatic, and if it were the safety switch, you wouldn't hear either the relay or the solenoid clicking.
But it would be helpful to know what transmission is in the truck.
Old Jul 8, 2014 | 03:47 PM
fluidp's Avatar
fluidp
found a broken wire the small one going to the starter
Thanks guys
Old Jul 8, 2014 | 08:26 PM
DIYMechanic
Glad to hear you found the issue.
GuppiesStuffies
1983 - 2012 Ranger & B-Series
Nov 10, 2017 02:59 PM
D_A_G_1263
Nov 29, 2016 09:26 PM
flatbed444E
13
Jan 20, 2014 06:04 PM
RedDragon
19
Dec 9, 2011 10:32 AM
Big Chill
Mar 1, 2011 06:49 AM
