E4OD not shifting into gear - challenging problem
Old 03-03-2012, 06:07 PM
RIKIL's Avatar
RIKIL
RIKIL is offline
I just ran the 351W I built through its initial 30 min break in period. So far so good with the motor. The transmission won't engage into any gear (forward or reverse), only the parking gear seems to work.
The background of this is that a couple of years ago I upgraded from SD to MASS Air and in order to get the MASS Air computer to work with an E4OD, I have one of these - Baumannator TCS. As far as I can tell this is setup and working properly. Need to wait until Monday to call them to get their thoughts on this whole issue.
I removed the transmission pan when the motor was out and I replaced some parts (reconditioning kit). What I did wasn't hard or complicated, I didn't go too far into the transmission. I feel I put it back together fine but I am no expert.
I also had a custom built torque converter. I filled the transmission so the dipstick is full but I am not sure if fluid has got through the entire system yet, I think I still need to add another gallon of fluid.
This is sort of a first shot in troubleshooting and a shot in the dark because I realize I have a custom setup but I think there has got to be a basic set of tests or something I can do to see what parts work and what parts don't work.
Anyone?
Old 03-03-2012, 06:47 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
FORDF250HDXLT is offline
she's not going anywhere that low on juice.
your first test is to start it,make sure fluid is flowing through the cooler,and topping up the fluid asap before you hurt the pump or converter.
she'll have reverse and 2nd (in manual 1st or 2nd position) without any electrical.
Old 03-03-2012, 07:16 PM
RIKIL's Avatar
RIKIL
RIKIL is offline
I shifted through all gears. I didn't feel the tranny reacting
Old 03-03-2012, 07:31 PM
FORDF250HDXLT
no.it wouldn't if she really is a gallon low on trans fluid.
Old 03-03-2012, 11:06 PM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,172 Likes on 926 Posts
You will need around 16 to 18 quarts to fill that transmission and torque converter.
Old 03-05-2012, 09:51 AM
Kemicalburns's Avatar
Kemicalburns
Kemicalburns is offline
did the tranny come out of the truck for any reason? perhaps the solenoid pack is fouled up or not connected. this will keep the tranny from going thru the gears also.
but like said above make sure you have the proper amount of fluid in there.
Old 03-05-2012, 09:59 AM
RIKIL's Avatar
RIKIL
RIKIL is offline
Maybe I wasn't patient enough. I thought it wasn't taking any more fluid but it actually is. I didn't run it yesterday, worked on other things but hope to get to it this week.
Old 03-09-2012, 04:36 PM
RIKIL's Avatar
RIKIL
RIKIL is offline
So far things seem to be fine with the motor and the tranny is still taking in some fluid but I ran into something that made want to stop and see if this is right.
My first issue is that I don't know 100% how much fluid is in the tranny but a good guess is ~3.5 gal. It's taking in fluid but not as fast and it is shifting into all the forward drive gears. I haven't yet moved the truck under the power of the transmission because when I shift into reverse, I hear a noise like metal rubbing so I shut everything down right away.
I just didn't want to proceed if this doesn't sound right.
Old 03-09-2012, 06:14 PM
RIKIL's Avatar
RIKIL
RIKIL is offline
I realized the Baumann Transmission Controller didn't have power, the fuse was loose. I'll see if that makes a difference tomorrow.
Old 03-09-2012, 06:59 PM
Encho's Avatar
Encho
Encho is offline
The Southernmost Mod
If you ran that transmision with low ATF for a long while (and i mean like 10 minutes) the heat probably caused some damage, that's a shame...
Old 03-11-2012, 12:15 PM
RIKIL's Avatar
RIKIL
RIKIL is offline
Yeah, something is wrong where I don't want to push it. I wouldn't consider this a major issue, I was planning on having it rebuilt anyway (it can't handle the power of the motor). Just need to do it sooner than later. It's just money, right? I mean this is my Ford we are talking about here
Thanks for the help.
77 steve
31
02-10-2024 11:02 AM
latechbanjo
18
08-16-2016 08:29 PM
davro37087
07-24-2015 02:44 PM
boeingguy747
07-01-2007 01:56 AM
Skandocious
10-03-2006 12:56 AM
Quick Reply: E4OD not shifting into gear - challenging problem
