Getting a kick from Park to Reverse
Old Oct 2, 2006 | 09:39 PM
Skandocious's Avatar
Skandocious
I've got a 1995 F150 5.8L 4wd with an auto trans. When the truck has been parked for a bit and I fire it back up to back out of a spot, I first get a rather long pause until it kicks into gear (maybe half a second to a second, seems unhealthy though) and then a rather jarring KICK into gear, not only felt throughout the truck but even heard! Any clue what this might be?
Old Oct 3, 2006 | 12:56 AM
pud's Avatar
pud
check the fluid, if fluid is full then it sounds like youre torque converter isnt locking up. Do you have to idle it up a bit? it could also be a bad U-joint, but it sounds like the torque converter. Try the tranny forum, the E4OD can be a real hoe-bag when it breaks, so Ive read many of times.
