Sponsored by: Real Truck
3v 5.4 broken plug
Old Mar 3, 2012 | 02:12 PM
FoxNotch's Avatar
FoxNotch
3v 5.4 broken plug
Big surprise, I tried to change a plug in a 3v and it broke.
I'm a little confused though, as none of the breakage that I have seen online matches what I have here.
I followed the TSB, and when I applied pressure on it, it loosened very consistently and really quite easily; I thought I was lucky.
So anyway, I backed it out until the point I was spinning the socket with my fingertips, but if I tried to pull it out by the top of the electrode, it is stuck in there.
So am I correct to assume that the hex/thread portion broke free from everything else, and the porcelain/electrode/sleeve are seized in there?
Such being the case, has anyone ever tried to crank the engine, and use the compression to push these parts out? What could go wrong here?
BTW the lisle tool was ordered a few days ago, should be here monday or tuesday.
Thanks for any help.
Old Mar 3, 2012 | 04:50 PM
FoxNotch's Avatar
FoxNotch
I thought a little more about the "compression removal" method.
150psi of cranking pressure will shoot that thing like a rocket. Even if I lay a welding blanket over the engine like I had planned, I wouldn't want any shattered porcelain by any chance falling back into the combustion chamber.
So I guess I'll just wait for the tool to get here. If I had an open field to do it in, I would probably take the hood off and give it try just to see what happens, against my better judgement.
Old Mar 3, 2012 | 05:33 PM
redford's Avatar
redford
FTE Leadership Emeritus
Yes, I would be worried about sucking something down into the combustion chamber. Why risk doing more damage? The correct tool is on the way, just wait for it.
Old Mar 18, 2012 | 09:23 PM
FoxNotch's Avatar
FoxNotch
The lisle tool worked great. $60 very well spent in my book.
Follow-up thread here: https://www.ford-trucks.com/forums/1...l#post11592391
kramerpage
2004 - 2008 F150
Feb 8, 2015 08:16 PM
silly34
Mar 9, 2013 12:28 PM
FoxNotch
Mar 19, 2012 04:13 PM
theman79
2004 - 2008 F150
Jul 10, 2011 10:04 PM
Scheib
2004 - 2008 F150
May 18, 2011 02:32 PM
