Sponsored by: Real Truck
Tow Haul problem
Old Mar 3, 2012 | 09:43 AM
Haakeyez50's Avatar
Haakeyez50
Question Tow Haul problem
Hi: I have a tow haul problem with my 2008 F350 6.4L. It will not go into tow haul unless I tilt steering wheel up all the way and than slam it down and than it will engage. Than when I want to take it out, I have to shut off truck. Does any one have a wiring diagram and info on how to get at the wiring. Do I have to disarm Air Bag and pull Steering wheel? It has been like this for a year or more and no warranty on that part they tell me. Any help should help, haakeye50@yahoo.com
Thanks Haakeye
Old Mar 3, 2012 | 02:59 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Take the plastic cover off of the steering column. The screws are underneath. You will see the damaged wires where they enter the shift handle. Either repair the wires or replace the handle. A new one is about $65 from a dealer.
You don't have to disarm the airbag or remove the wheel.
Old Mar 11, 2012 | 09:59 AM
Haakeyez50's Avatar
Haakeyez50
Smile Thanks
Thanks Mark
I tried to figure out wiring and switch and than bought a new lever and switch. $65.09 works well now. I than took the old one apart even further and found the broken wire, I repaired that wire and now I have a spare unit.
Thanks again.
Old Mar 11, 2012 | 02:31 PM
Kajtek1's Avatar
Kajtek1
Would that fit 2000?
I bought the truck with the switch broken but hesitate to buy new one not knowing if that is the only problem.
How important is switching to tow on this transmission?
Old Mar 11, 2012 | 03:23 PM
jsimon724's Avatar
jsimon724
Two different transmissions. 2008 is 5speed Torqshift, 2000 is 4speed. Torqshift has tow haul mode. Older trans only has overdrive off button. Completely different animals.
Old Mar 11, 2012 | 05:57 PM
Mark Kovalsky
But the shift handle is the same, except the lettering on the newer one says Tow/Haul while the older one says OD OFF. Other than the lettering they are identical.
Old Mar 11, 2012 | 06:29 PM
Kajtek1's Avatar
Kajtek1
So is on my transmission pushing the button or downshifting with the level bringing the exact results?
Old Mar 11, 2012 | 06:38 PM
Smokeispower's Avatar
Smokeispower
I can't remember exactly if it's the same result, but your owner's manual will have the details.
Old Mar 11, 2012 | 06:51 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
are you talking about how the button affects the trans?
03+ trans "Tow/Haul" changes the shift points on the trans so it will stay in gear longer to allow higher revs
03 and older "On/Off" turns off overdrive and drops the truck into 3rd gear
Old Apr 16, 2013 | 07:01 PM
2,4shofast's Avatar
2,4shofast
Originally Posted by Haakeyez50
Thanks Mark
Thanks again.
I was wondering if either of you might know the part number on this? My local dealer was trying to tell me it was $380. Thanks in advance!
Old Apr 16, 2013 | 08:47 PM
Mark Kovalsky
The base part number is -7210-. Any Ford parts counter can find the right one for your truck with this number. Official Ford Parts Site | Buy Motorcraft & OEM Ford Parts Online | FordParts.com shows it at $55.10.
Old Apr 16, 2013 | 09:18 PM
2,4shofast's Avatar
2,4shofast
Thank you very much Mark, that is exactly what I was looking for!
Old Sep 26, 2013 | 12:31 PM
2,4shofast's Avatar
2,4shofast
Using the information Mark provided I was able to get the part and fix the issue, thanks again everyone!
Old Sep 26, 2013 | 06:11 PM
redford's Avatar
redford
FTE Leadership Emeritus
If someone on the forum is helpful, a way of showing thanks is to give them rep points. (Them green dots on the right of someone's post show how many rep points they have).
To give someone rep point, click on the little heart shaped icon in the upper right box of the post you like, then fill out the pop-up window.
jkey.bama
Jan 28, 2014 05:17 PM
freakville03
Apr 25, 2012 09:09 AM
bill baughman
Apr 10, 2011 09:19 AM
sdetweil
Sep 17, 2009 06:57 PM
bascobunch
Apr 25, 2006 03:30 AM
