fuel pump plunger help
Old Mar 2, 2012 | 06:34 PM
Byrddog's Avatar
Byrddog
I've gone and done it friends.
I was replacing my fuel pump and the plunger was still in the hole, when I grabbed it with the magnet it shot down the passenger side of the hole. I can't see it and when I stuck the magnet down inside a little I could not feel it.
So is there something I can do or am I screwed?
Old Mar 2, 2012 | 06:57 PM
mojoman's Avatar
mojoman
its not happened to me...but I have read some folks turn the motor over by hand slowly and you can hear it hit the oil pan...someone with more experience will chime in...my pump was installed last week and the plunger came out with the pump....good luck!!
427 fordman's Avatar
427 fordman
One of the guys on here has his laying in the pan just because of that. I'd crank over the ignition slowly by hand to make sure nothing is binding then put a permanent magnet on the pan to hold it there and go if it were me. Heck, I lost an allen wrench while doing my injectors, I think its inside the motor somewhere, looked for many hours in and around the motor and didn't find it.
Old Mar 2, 2012 | 07:51 PM
BuckHammer's Avatar
BuckHammer
Good luck. I hope everything turns out okay.
Old Mar 2, 2012 | 09:14 PM
fordpride's Avatar
fordpride
You have two choices. 1. Leave it in the pan. 2. Pull the motor
Old Mar 3, 2012 | 12:30 AM
Oldsmoky92's Avatar
Oldsmoky92
I feel your headache, I pulled my turbo last nite and dropped a nut in the pass intake, I know, why didnt I have a rag in them.. I was able to pull the manifold and retrieve it with a magnet. As for a good magnet that is y enough I broke apart an old cam sensor and it had a little magnet that is quite powerful, I pinched it with a cable claw and it worked very well.
Old Mar 3, 2012 | 07:12 AM
Byrddog's Avatar
Byrddog
Thanks guys. Im going to see if i can retrieve it this morning and if not hope that it drops to the pan.
Wendy71
Feb 15, 2016 05:13 PM
johnred
Jun 14, 2011 02:37 PM
jimwilsonmasonry
28
Jul 21, 2008 04:32 PM
jlh65791
Apr 13, 2003 07:55 PM
