Ok so for a while my truck would lope on start up only when hot and sometime stall when coming to a stop or almost stall but it would barely catch its self.... But now it lopes when cold and still stalls when coming to a stop when I release my clutch. But still doesn't stall every time just sometimes.... I just replaced the cam sensor cause I thought that's what it would be but it's still doing it... Could I be the ipr? Any thoughts are appreciated! Thanks
Mine did similar. Ended up being the Hpop. Tried a new ipr first as I was going to put a new ipr in even if I replaced the pump. So it was a good first try.
Don't know about cel I'll have to look next time lol I just start it up or pop start It lol but after I start it up there isn't one that much I do know
It could also be Injector o rings. Mine were flat pitaful for the 3000 miles on them. They let HP oil bleed by and cause a no start issue any time with out extra rpm besides normal cranking.
