Glow Plug Question
Old Mar 2, 2012 | 11:50 AM
johnarahill's Avatar
johnarahill
Glow Plug Question
I know this is a JV question, but do the glow plugs do anything after the motor is running?
Old Mar 2, 2012 | 11:54 AM
nlemerise's Avatar
nlemerise
Strictly speaking no, but they may run for a total of two minutes whether the truck is running or not.
Old Mar 2, 2012 | 04:38 PM
Ponyboychris's Avatar
Ponyboychris
They only aid in start up like Neal said. Can be up to two minutes after you turn the key to the run position.
Old Mar 2, 2012 | 05:23 PM
japaleno's Avatar
japaleno
So even after the engine is running, they could continue to 'glow' for up to two minutes?
Old Mar 2, 2012 | 06:26 PM
nlemerise's Avatar
nlemerise
That is correct...the PCM uses temperature, barometric pressure, and oil temperature to determine how long the glow plugs should be on. That is one reason I put an led which lets me know when the GPR is commanded on by the PCM...others have just put a manual switch to turn on/off GPR.
DrCharles
Dec 10, 2017 06:20 PM
tygerrrr
May 12, 2011 11:21 AM
RRranch
Nov 8, 2010 03:23 PM
mitchntx
General Diesel Discussion
Jan 18, 2007 02:23 PM
Tha50Kid
Oct 15, 2003 03:22 PM
