Modular V10 (6.8l)
unplug coils from harness - how?
Old Mar 2, 2012 | 09:11 AM
ejgford's Avatar
ejgford
This question is for a 2000 6.8l. Is there a special tool used to disengage the coil on plug from the wiring harness? Just can't seem to figure out how to unlock it and don't want to break it.
Old Mar 2, 2012 | 09:39 AM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
On the underside of the plug that goes onto the coil there is a small lock lever that you have to depress to unlock it. Practice on 1&2 first before you try 5.
Denny
Old Mar 2, 2012 | 09:54 AM
TrdLtly's Avatar
TrdLtly
TreadLightly
Not exactly but similar to this:
Old Mar 2, 2012 | 10:00 AM
ejgford's Avatar
ejgford
Got it! Thanks.
I also figured out the clip on the harness for the fuel injector. I barely touched it before it snapped. The harness is on there now but not secured, not locked. How do you deal with one of these breaking? Tape?
Old Mar 2, 2012 | 10:06 AM
TrdLtly's Avatar
TrdLtly
TreadLightly
You may be able to cable-tie in place, but plan on replacing it as in the end it could cause you some issues.
Old Mar 2, 2012 | 10:09 AM
ejgford's Avatar
ejgford
What kind of issues does the broken harness clip to the fuel injector cause?
Old Mar 2, 2012 | 10:20 AM
TrdLtly's Avatar
TrdLtly
TreadLightly
Wiggles or vibrates loose over time. I was going to find more information pertinent to your vehicle, but your "about me" is showing an F150 only.
https://www.ford-trucks.com/forums/9...r-harness.html
See if this link help:
More Information for ACDELCO PT2160
You can search "Fuel Injection Harness Connector"
Old Mar 2, 2012 | 10:29 AM
ejgford's Avatar
ejgford
It's a 2000 Excursion. I also found these
Amazon.com: Ford Fuel Injector Wire Harness Connector: Automotive
Thanks
Old Mar 2, 2012 | 10:37 AM
TrdLtly's Avatar
TrdLtly
TreadLightly
Perfect. There ya go! Have fun.
Old Mar 3, 2012 | 08:06 AM
JWA's Avatar
JWA
NAPA also sells the COP connectors with one each black and white pig tail leads, p/n EC259 @ about $20 each.
HTH
SDSC4X4
Modular V10 (6.8l)
Jan 2, 2019 09:08 AM
handifletch
Modular V10 (6.8l)
Aug 16, 2018 09:32 PM
Homer Simpson
Jul 31, 2018 06:54 AM
fordman50
Aug 31, 2012 10:05 AM
Fullcrew7.3
33
Jul 18, 2011 07:53 PM
