ICP wiring harness
Old Jun 29, 2011 | 01:27 PM
Fullcrew7.3's Avatar
Fullcrew7.3
ICP wiring harness
I've got an odd problem. I need a new wiring harness or at least the connecter for the ICP. I got a 1212 code the other day and realized I'd gotten the harness wet (with biodiesel) when changing out the fuel filter. Now the wiring is bare as the B100 ate the rubber coating and seal in the plug at the ICP. Truck still runs fine, but the CEL is always on and I'm still getting a 1280 code after playing and trying to reseal the harness and plug.
Long story short, where can I get a new harness?
Old Jun 29, 2011 | 02:37 PM
Talyn's Avatar
Talyn
You could repair it like I did.
Mines been completly re-done due to a ... mistake like yours.
You can pull the harness, and pull the pins outa the main connector and slip heat shrink down it.
After i heat shrinked it, I pulled the wires away from eachother and RTV'ed in the connector, than redid the whole harness with shrink wrap pieces to make it pretty, then new wireloom.
Talyn's Avatar
Talyn
It's the same as an injector connector. so if your connector is trashed, you can wire in an injector plug from a bad UVCH.
Old Jun 29, 2011 | 03:03 PM
Fullcrew7.3
That might just do it. Thanks Talyn.
Old Jun 29, 2011 | 03:38 PM
Copedawg's Avatar
Copedawg
Pete showed me this: Ford F250 6.0 7.3 ICP Sensor Connector Kit 5C3Z-12224-A | eBay
But I got one from the junk yard. I unplugged it and plugged it back in and I haven't had any problems since. (I think it the connector is bad somewhere) I will replace it when I get a chance (stuck on the side of the road, lol)
Old Jun 29, 2011 | 04:22 PM
Fullcrew7.3
I was planning on checking out the (only) local wrecker, but they don't really have any diesels. It sounds crazy, but hey that's what there is......
Old Jun 29, 2011 | 04:25 PM
Copedawg's Avatar
Copedawg
Not much on 259, huh?
Old Jun 29, 2011 | 04:53 PM
Copedawg's Avatar
Copedawg
I may go to the junk yard tomorrow (I am in search of IDM's), If I see a ICP harness, would like me to snip it out for you?
Old Jun 29, 2011 | 04:55 PM
Copedawg's Avatar
Copedawg
OH, I had no idea where Harding MB was (I didn't even know it was in Cananananada!) so I ggogled it harding mb - Google Maps Thats where the 259 comment came from. Looks like good fishing to the west
Old Jun 29, 2011 | 06:32 PM
quesey's Avatar
quesey
got this for a buddys truck
Ford Powerstroke 7.3l 6.0l VGT IPR Connector with Seal | eBay
Old Jun 29, 2011 | 06:48 PM
Fullcrew7.3
29 bucks is certainly better than $60. I'll see about hitting the wreckers when I go through the city on the weekend. Otherwise, Talyn's fix should do for now. Thanks guys.
And yes Ian, I'm from the far north.
Old Jun 29, 2011 | 07:05 PM
plgebbia's Avatar
plgebbia
ICP or IPR connector? I see both mentioned in the thread.... Either way, I have what you need. PM me if you are still looking
Old Jun 29, 2011 | 10:09 PM
Talyn's Avatar
Talyn
Oh, he did say ICP. I had a brain fart.
Was getting ready for work and posting.
The same concept will work on the ICP connector though as well.
It's just not a UVCH plug. Doh!
Old Jun 30, 2011 | 07:08 AM
Fullcrew7.3
Thanks Ian. I'll check out the wrecker and if that doesn't work out, I'll shoot you a note.
Old Jun 30, 2011 | 09:10 AM
plgebbia's Avatar
plgebbia
No biggie Talyn, I just wanted to make sure everyone was on the same page
Just let me know, I'd be glad to help.
