Sponsored by: Real Truck
Light dinging wont stop!
Old Mar 1, 2012 | 09:52 PM
mjc3276's Avatar
mjc3276
I turned off the truck the other day and the Hey genius you left your lights on dinger was was going off. Thing was, the lights werent on. I moved the key lock slightly and it quit... starting up again 30 seconds later. I went to start her up n the battery was dead. Any ideas?
Old Mar 2, 2012 | 06:41 AM
Smokeispower's Avatar
Smokeispower
If you search the archives I think there's an article on disconnecting the wire(s) for the key minder. I think that would be the cheapest way to deal with the issue. But you'll have to remember to remove the keys (same chime as the lights on warning).
Found it - a few different methods of killing the chime https://www.ford-trucks.com/forums/1...oor-chime.html
Old Mar 2, 2012 | 08:28 AM
mjc3276's Avatar
mjc3276
Thank you. I will read up on it and do it tonight. The chime killed my battery in 4 days.
Old Mar 3, 2012 | 08:12 AM
mjc3276's Avatar
mjc3276
Update
Its not the chiming. The truck is not turning off... battery is still supplying power to the windows and radio! Ignition is in locked position and key is out. Any thoughts?
Old Mar 3, 2012 | 08:31 AM
PA-Mark's Avatar
PA-Mark
i bet you need a new ignition switch, this is just a guess, but without being there to actually test it this is the best i can come up with... its probly shorted inside the switch ive seen it happen before on other vechicles
Old Mar 3, 2012 | 10:05 AM
mjc3276's Avatar
mjc3276
frustrating. Imma just disconnect the battery until I get some time to mess with it. I cut the black and pink wire. Replacing the whole assembly will be a PIA.
Old Mar 3, 2012 | 10:22 AM
Quad Racer's Avatar
Quad Racer
Is there some cleaner you could try to spray in there? Just as a temporary fix?
Old Mar 3, 2012 | 11:13 AM
mjc3276's Avatar
mjc3276
I got it to stop. I locked the steering wheel and the dinging ceased/ power was cut to the windows and accessories. Luckily Advance does free battery test and charging.
Old Mar 3, 2012 | 11:35 AM
mjc3276's Avatar
mjc3276
That may not be a bad idea. it is an 11 year old beast...
Old Mar 3, 2012 | 08:18 PM
mjc3276's Avatar
mjc3276
Update... So i got ahead of myself. Issue is still going on. I have resorted to disconnecting the battery until its resolved. Annoying. Yes. But thats life.
Im not feeling the third and fourth positions in the ignition switch like i should. It goes to the position and the key is removed like it should but theres no defining position click.
Jamie Midgette
Jan 18, 2019 04:01 PM
fastwheeler
Electrical Systems/Wiring
Nov 26, 2014 10:09 AM
cbb
1997 - 2003 F150
19
Apr 5, 2005 05:51 AM
zman084
Dec 13, 2004 05:00 AM
jondm
Sep 10, 2004 10:08 AM
