Studs with cab on?
Old Mar 2, 2012 | 01:56 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Post
Originally Posted by Ian123
IIRC, the booklet that came with my torque wrench told me that would make the reading inaccurate.
that little booklet is wrong
We use the Joint Fleet Maintenance Manual for all of our Submarine Safe Work (I am stationed on my 3rd Submarine here in Pearl Harbor). Been putting together, and then torquing joints that quite litterally can mean the difference between life and death for >10 yrs. Torque is a funny thing.
Check out Part 1, Chapter Five, Section 5.3
http://www.submepp.navy.mil/jfmm/doc...Volume%20V.pdf
There is also a ton of great info in there on joint make-up and general assembly. I suggest you guys check it out. Almost everything in that manual is very useful IMO. A bad o-ring caused the Challenger failure...it's the little things you have to pay attention to!
Old Mar 2, 2012 | 02:02 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Originally Posted by AndeyHall
Is there a way to get our hands on the factory book?
you can purchase the "book"...or paper version for $100-200
or
you can buy the OEM Ford repair DVD's for about $5-25. I get them off eBay. I've bought them for all of my Fords. To date have a 2005/2006, 2007/2008, 2009/2010. They come with all Wiring Diagrams, HVAC, and all procedures and diagnostics. Even has the TSB's that were available at time of release.
very good tool. I've got a few paper manuals and they are easier to use at the jobsite, but the DVD's really cut down on the clutter. And they're great to print so you don't mess up your nice book.
here's a few links to one for your truck
Ford 2000 2001 2002 2003 Mustang Cougar Focus DVD Service Manual | eBay
2003 - 2004 Ford Car & Truck Service Manual DVD Includes F150 & Powerstroke | eBay
Old Mar 2, 2012 | 07:16 AM
AndeyHall's Avatar
AndeyHall
or
Sorry guys I keep forgetting I have a signature. The 03 in my signature has been sold. The truck that I get on here now for is an 06 SRW 350.
Old Mar 2, 2012 | 08:06 AM
Boss9F100's Avatar
Boss9F100
Originally Posted by 69cj
That's a must for 240+ ft. lbs. in my book.
Actually, THe proper torque for ARP head studs is 210 not 240+
If it takes under 2 hrs to remove the cab why would one even think trying to do the job without cab removal? Install the cab in under a hour . . . Thats with it being rolled out of the way.
Old Mar 2, 2012 | 08:23 AM
AndeyHall's Avatar
AndeyHall
...when you have no way of getting the cab up. Not everyone has a 2-post lift or some sort of ceiling hoist.
Old Mar 2, 2012 | 05:57 PM
cheezit's Avatar
cheezit
because it takes 3 hours to remove the heads with the cab on.
also if you worked on as many bucket trucks and meat wagons as I do you would get it.
Old Mar 3, 2012 | 09:32 AM
Curt's05's Avatar
Curt's05
Wiser by FTE
Studs won't help with mileage, when i first did the studs/ egr delete and an innovate tune. I was up to 18 mpg on a freeway trip to branson mo, very light right foot!~
Old Mar 3, 2012 | 11:08 AM
AndeyHall's Avatar
AndeyHall
Well I knew it wouldn't help mileage, I was just wondering if there might be some reason that all the people that have had it done at this shop went from high teens or 20mpg or so down to low teens. They're getting worse mileage unloaded after studs than they were with a loaded trailer before studs.
Old Mar 3, 2012 | 12:28 PM
John Irwin's Avatar
John Irwin
Since studs couldn't possibily make a difference in the fuel mileage, (they don't weigh that much more than the bolts) something else must have happened, like a reflash, or different heads, or something egr related. Can't see it being the studs.
nodesy
Jan 18, 2014 11:28 AM
AndeyHall
Jul 21, 2011 10:00 PM
dcaddi2
Jun 15, 2008 04:46 PM
SOB Racing
May 24, 2008 09:28 AM
Dustball8504
Oct 9, 2007 12:11 AM
