Stupid newb question
Old Mar 1, 2012 | 10:19 AM
Red460's Avatar
Red460
Arrow Stupid newb question
Just bought a 95 F-250 PSD and had a dumb question where is the high beam switch? Do I pull the **** all the way out? Pushed all the way in is that for normal headlight power? Someone give me a heads up.
Old Mar 1, 2012 | 10:31 AM
Lazy K's Avatar
Lazy K
My truck is `87 so have floor switch for high and low but on yours pull the **** all the way out and then flick the multi-function stalk towards you for high and low.
Old Mar 1, 2012 | 10:32 AM
Conanski's Avatar
Conanski
I think you just push the turn signal stalk forward to select hi/lo beam, I'm not 100% sure since my truck has the old-as-the-hills switch on the floor setup.
Old Mar 1, 2012 | 10:51 AM
Prof2113's Avatar
Prof2113
Push the stalk forward on my '96.
Old Mar 1, 2012 | 10:53 AM
76250_4x4's Avatar
76250_4x4
pull the headlight switch all the way out. Then push your directional stalk forward
Old Mar 1, 2012 | 12:20 PM
Red460's Avatar
Red460
Thanks everybody I will try that. For some reason I figured it would be on the floor. I gotta replace the steering wheel and the loose turn signal switch on the column along with the dash lights, this will be a fun dash project.
AKHunter93
Aug 3, 2015 05:57 PM
filthy6
Mar 30, 2014 12:27 AM
smartasafart
Sep 26, 2006 03:46 AM
fordman363
Aug 31, 2006 01:16 PM
gingerbreadmaniac
Sep 10, 2005 11:16 PM
