dumb headlight question
Old Mar 29, 2014 | 11:02 PM
filthy6's Avatar
filthy6
56 F100. I couldn't tell during the daylight and returned the battery to the donor truck before dark. When the high beam lights are on, is that in addition to the low beams or instead of the low beams. Using my power probe to power each wire independently it looked like they may be independent of each other. I don't know if the bright/dim switch on the floor combines the two. My floor switch is intermittent at best. Bye the way, the power probe is a great tool for people who are not adept with a digital multi meter. Best $100.00 I have spent......twice.
Old Mar 29, 2014 | 11:11 PM
ALBUQ F-1's Avatar
ALBUQ F-1
AFAIK all '50's Fords are "either or", low beams or high beams, the floor switch directs power to one of the two, never both. NAPA sells floor switches cheap:
NAPA AUTO PARTS_Headlight Dimmer Switch
Old Mar 29, 2014 | 11:34 PM
Rollingmenace's Avatar
Rollingmenace
I agree either on or off... Some headlight switches will activate both at same time only while the switch is depressed .. Once you let off it will change states to either hi or low....
Old Mar 30, 2014 | 12:10 AM
filthy6's Avatar
filthy6
Thanks guys that's what I thought. I needed to know that before I could proceed with all of my headlight, parking light, taillight wiring. Now I'm on my way. The people on this site are the bomb. Matt
Old Mar 30, 2014 | 12:27 AM
CharlieLed's Avatar
CharlieLed
The sealed beam headlight would get really hot if both elements were on simultaneously.
AKHunter93
Aug 3, 2015 05:57 PM
Twilight Fenrir
16
Sep 22, 2012 01:13 PM
gingerbreadmaniac
Sep 10, 2005 11:16 PM
xfordtech
Electrical Systems/Wiring
Aug 31, 2005 01:01 PM
opjgeorge
Mar 26, 2003 03:36 PM
