Engine Pics
Old Mar 1, 2012 | 10:52 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Originally Posted by mueckster
Taken from my Ford manual:
The PCM receives engine rotational position information from the Camshaft Position (CMP) sensor. The CMP is a hall-effect device. It outputs 12 volts to the PCM whenever it detects the iron of a spoked target wheel in front of it, and it outputs 0 volts whenever it detects the space between the spokes. The target wheel spokes and spaces are each 15 crank degrees, except for narrow spoke which indicates cylinder No. 1 and a wide spoke which indicates cylinder No. 4 (fires 5th). The NGS PID RPM is generated by the PCM from the CMP signal.
Good stuff
Wonder why 1 and 4 are different.
Old Mar 1, 2012 | 11:13 AM
woodnthings's Avatar
woodnthings
They are different so the PCM knows where the engine is at based on the cps signal. This is how the timing is calculated and the PCM knows which cylinder it is on.
Old Mar 1, 2012 | 11:15 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Ahh ok good point. Otherwise it would be arbitrary and it could be anywhere.
Sounds like the PCM has short term memory loss....
"1, 2, 3... ummm what? OH! That means 4! SWEET!... 5, 6, 7, 8... ummmmm.. OH! 1 again. YES! 2, 3... uhhh..."
Old Mar 1, 2012 | 11:18 AM
Shake-N-Bake's Avatar
Shake-N-Bake
Originally Posted by A/Ox4
Good stuff
Quicker starts. The sensor picks up either #1 or #4 and sets the timing accordingly.
Old Mar 1, 2012 | 03:50 PM
danskool's Avatar
danskool
Go Bills !
That funny.
Old Mar 1, 2012 | 04:21 PM
woodnthings
Here is the Cam Wheel with the targets marked up and the firing order added.
Old Mar 1, 2012 | 06:31 PM
Pitcrw6's Avatar
Pitcrw6
What do you plan on doing to the eng? What kind of upgrades and mods? Is this a spare eng you have? What yr? Sorry for the questions but just wondering.
Old Mar 1, 2012 | 07:08 PM
JOHN2001's Avatar
JOHN2001
Originally Posted by timmyboy76
Hey Doc..EXCELLENT thread, bud...reps to ya. Now if i know how to rep...
There is a "heart" at the upper right hand side of each of our post, click on whoevers "heart" you want to rep... youll figure out the rest its self explainatory
Old Mar 2, 2012 | 04:31 AM
Nsaan's Avatar
Nsaan
This made me laugh, It took me a second to realize you weren't talking to me... that has been a nick name that people started calling me 20 years ago. I guess I have not let that out on here yet.
I have been trying to figure out hall effect devices for a while now. We use them in Gas pumps as pulsers, so the computer can know how much fuel you pump. It is 500 pulses per gallon.
Old Mar 2, 2012 | 04:33 AM
Nsaan's Avatar
Nsaan
duplicate post
Old Mar 2, 2012 | 08:22 AM
snakedoc's Avatar
snakedoc
it is going to be stock other then some orings form Bob. i bought a 450 with a bad motor the one on the ground and i going to put this motor in the 450.
Old Mar 2, 2012 | 12:28 PM
dmanshane's Avatar
dmanshane
I would like to see the rear main seal area and the back of the engine me and a friend are dightin an oil leak we are pullin tranby to tomorrow some pics would be awesome like of block plugs and stuff on the back of the engine
Old Mar 2, 2012 | 05:13 PM
  #28
snakedoc's Avatar
snakedoc
here is a pic of the stand holder.
i will see if i can get a pic of the main seal later right know im under a tornado warning.
underthebridgejim
13
Mar 20, 2014 11:54 PM
shacks87
85
Jan 7, 2010 11:45 AM
ford390gashog
Feb 8, 2006 09:30 AM
Black Ford XLT
Jan 9, 2005 12:33 PM
