Freeze Plug Leak
Old Jan 8, 2005 | 06:16 PM
Black Ford XLT's Avatar
Black Ford XLT
Freeze Plug Leak
Freeze plug seems to be leaking behind the drivers side of motor mount 1992 351 bronco .Any tips on changing the plug out engine still in and removing motor mount( engine have to be lifted) and where else do i have to unbolt the engine besides motor mount. From a previos search i found u have to undo the bolts from the block and slide the mount out . I f i have to lift the engine wheres the best place All replies appreciated -Haynes shows changing the plugs with the engine out.thanks TR
Old Jan 8, 2005 | 06:29 PM
xltlariat87's Avatar
xltlariat87
changed on my '85 about a year and a half ago. i parked the truck under a tree, drained the block, used a chain block and lifted the engine as far as i could, then changed both freeze plugs while engine was up.
Old Jan 9, 2005 | 12:33 PM
daerhldgs2's Avatar
daerhldgs2
undo both mts and put a piece of 2X6 under tha pan and jack on it , don't raise it any more than necessary, drive the plug in on one side and it will sit sideways in the hole then grip it with vise grips and pull it out, don't put the new one in too deep and be sure you clean the block thoroughly before you install the new one.Have fun!!
StephenM
Feb 25, 2017 08:31 PM
Tparkin99
13
Jan 29, 2017 02:35 AM
SoCalAngler
Modular V10 (6.8l)
Jun 12, 2016 09:39 AM
jetfiremuck
Aerostar
Nov 8, 2015 12:05 PM
r59
15
Jan 13, 2013 10:40 AM
