Engine Pics
Old Feb 29, 2012 | 04:26 PM
snakedoc's Avatar
snakedoc
Engine Pics
i have an engine on the stand right now if you know of something you heed a pic of let me know and i will see what i can do.
here are some of it, and an motor on the ground.
i dont know what you use to keep your bolts organized but i have a lot of VHS cases that work great.
Old Feb 29, 2012 | 05:07 PM
Shake-N-Bake's Avatar
Shake-N-Bake
When looking directly at the front of the block, there is a hole just outside of the cam gear, about the 1 o-clock position.
Where does that go to? Do you know what it might be for?
Old Feb 29, 2012 | 07:09 PM
JOHN2001's Avatar
JOHN2001
If you have taken out all the plugs on the block could you let me know what size the square plug is on the inspection hole where you can tell if you have PMRs or Forged rods
Old Feb 29, 2012 | 07:27 PM
woodnthings's Avatar
woodnthings
That plug is 5/16".
Old Feb 29, 2012 | 07:34 PM
JOHN2001's Avatar
JOHN2001
Originally Posted by woodnthings
That plug is 5/16".
Thank you
Old Feb 29, 2012 | 09:32 PM
snakedoc's Avatar
snakedoc
i will look and see if it can find out what the hole is.
Old Feb 29, 2012 | 09:38 PM
2000ca250's Avatar
2000ca250
Matt,
Could you take some pics of how it mounts up to the stand? Getting ready to pull mine in the next couple of months and just any general pics would be greatly appreciated. Would like to see how it should look so that I can be more prepared.
Old Feb 29, 2012 | 11:04 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
A picture of the gear that the CPS reads would be nice...
Old Feb 29, 2012 | 11:25 PM
Nsaan's Avatar
Nsaan
That would be the big gear in Gregs picture in post #2... the cam gear.
Old Mar 1, 2012 | 10:27 AM
snakedoc's Avatar
snakedoc
the ford shop manual says it is a anti-drianback check ball and spring. it looks like it is goes down to lpop right under it
here is a close up of the gear that the cps works off of.
Old Mar 1, 2012 | 10:28 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Thank you sir
Old Mar 1, 2012 | 10:30 AM
snakedoc's Avatar
snakedoc
no problem
im not sure how it works some of the holes are bigger and smaller?
Old Mar 1, 2012 | 10:31 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I think it reads the teeth.
Old Mar 1, 2012 | 10:45 AM
mueckster's Avatar
mueckster
Originally Posted by snakedoc
no problem
Taken from my Ford manual:
The PCM receives engine rotational position information from the Camshaft Position (CMP) sensor. The CMP is a hall-effect device. It outputs 12 volts to the PCM whenever it detects the iron of a spoked target wheel in front of it, and it outputs 0 volts whenever it detects the space between the spokes. The target wheel spokes and spaces are each 15 crank degrees, except for narrow spoke which indicates cylinder No. 1 and a wide spoke which indicates cylinder No. 4 (fires 5th). The NGS PID RPM is generated by the PCM from the CMP signal.
Old Mar 1, 2012 | 10:49 AM
timmyboy76's Avatar
timmyboy76
Hey Doc..EXCELLENT thread, bud...reps to ya. Now if i know how to rep...
