camshafts
Old Mar 1, 2012 | 12:19 AM
Bamadawg63's Avatar
Bamadawg63
Ice... I think what 79 was trying to convey is when you settle on what type of performance you want for the truck, call TMeyer at the link he gave and let them custom grind you a cam to meet those specific needs. Custom grinds are usually on par in price on most name brand cams, $200-$300 range. Then you will have a grind that is made to take advantage of every part of your package, from the pistons, heads, intake, headers/manifold on out to the pipe size you run. They take all that into account when they make up your own special recipe.
Cheers...
Nate
Old Mar 1, 2012 | 06:37 AM
79silverstreak's Avatar
79silverstreak
Most of the replacement cams you can get today, have 4 degree advance already cut into them. This with a straight up timing set alone will show the biggest improvement. Like Nate said, the differences in grinds comes down to you, what you plan to use your truck for, when do you like to shift, fuel efficiency, and so on. I'm just getting finished with my 400 build, .040 over, stock heads(all ready spent too much, couldn't get aussie) Tmeyer pistons, action plus intake, 650 annular Quick Fuel, Comp Cams XE256H-10, Should make 440 torque, ad 340 HP, with lots of grunt down low.
Old Mar 1, 2012 | 09:13 AM
iceman320's Avatar
iceman320
well I use the truck now for a daily driver sometimes. and will most likely start to use the truck to pull my atv trailer and maybe a 26 foot camp trailer someday. so the truck will be getting used as a dual purpose rig both as a daily driver and to pull my trailers sometimes.
Old Mar 1, 2012 | 09:30 AM
BACRAKR's Avatar
BACRAKR
i have a comp 270 in my truck and it is a great cam. Power every where. Sounds decent at idle too.
Old Mar 1, 2012 | 09:34 AM
iceman320's Avatar
iceman320
bacrakr, do you have a part number or a link to the cam that you have so that i could look at it on summitracing's website. and does it come in a kit with the new valve springs and stuff like that?
Old Mar 1, 2012 | 11:59 AM
Buck0's Avatar
Buck0
The link from USarmytaterness's post is for an FE series engine. You have a 335 series aka M series engine. That link will get you a cam you can't use. I think something from comp along those lines would do well but it needs to be for your engine.
Taterness - not trying to bust your *****, just trying to help the OP.
Old Mar 1, 2012 | 01:31 PM
iceman320's Avatar
iceman320
So then a cam with the same lift and duration ad posted above would work fine then?
Old Mar 1, 2012 | 02:50 PM
USArmyTaterness's Avatar
USArmyTaterness
No problem I looked at it again and you are right not sure how I missed that the first time.
Old Mar 1, 2012 | 04:04 PM
iceman320's Avatar
iceman320
ok I will try to find a cam with the same lift and duration as the one listed above then thanks for the help guys.
Old Mar 1, 2012 | 10:49 PM
iceman320's Avatar
iceman320
hey guys would this cam and lifter kit work good for my truck and what I will be using my truck for?
COMP Cams SK32-242-4 - COMP Cams Xtreme Energy Cam and Lifter Kits - Overview - SummitRacing.com
Old Mar 2, 2012 | 09:04 AM
BACRAKR's Avatar
BACRAKR
COMP Cams K32-224-4 - COMP Cams Magnum Hydraulic Cam and Lifter Kits - Overview - SummitRacing.com
I'm running a hydraulic roller but here is the flat tappet which is prob what you'd be more interested in.
Old Mar 3, 2012 | 07:16 PM
79silverstreak
Ice man,
That's the same cam I was gonna go for in the begging, but then I bumped down one to the one I got now, just to get stump pulling torque off idle. You won't have any complaints with this cam, I would not recommend going any bigger. If you were going to use the stock induction, I would advise against it, but like I said, with a new intake and carb, you won't have regrets about this cam using the truck for what you described.
Old Mar 4, 2012 | 09:07 AM
  #28
iceman320's Avatar
iceman320
What will the cam that i posted do to my mpg will my mpg go up or down the toilet?
Old Mar 16, 2012 | 05:23 PM
  #29
BACRAKR's Avatar
BACRAKR
my truck gets 10 mpg on the highway on 36's with 7" lift
BACRAKR
16
Jan 17, 2012 04:49 PM
AntiHero55
Jun 15, 2010 02:54 PM
552ford
May 27, 2008 05:58 AM
mstum00
Jan 10, 2005 09:46 PM
teamwizard
Apr 1, 2002 12:48 AM
