Hydraulic Roller Questions
The truck is a daily driver. Nothing radical, 4bl, long tubes, hei. Doesn't see over 5000 rpms. Don't really care how much power it makes, threw this engine together to get me through college reliably, key word reliably.
Lifters:
I don't want to use a spider tray, I don't like their design and favor link bars for multiple reasons (besides the price). I'm looking at the howards (Morel) link bar lifters because they are priced right.
Cam:
Comp 260HR 260/260-206/206-.510/.510-110
I would run a howards cam but their off the shelf stuff is a tad to big. I haven't asked what they charge for a custom grind but I'd assume they are more. Maybe I'm wrong? Don't need anything radical, and I'm trying to avoid machining the heads and having to deal with valve seals issues.
Valve Springs:
I need some help selecting valve springs. The truck is in a friends shop an hour away. I hardly have time to go back on weekends due to the amount of studying I have to do at college. And I'd like to have all the parts in my hands, go up and install them. Rather than install a part, measure this, install a part, measure this. I simply don't have 3 or 4 weekends to do that and I need the truck running. Can I run comp beehives, duals, other?
Anyways what springs do I need to go with so I don't have to machine anything on the heads and I can use the stock umbrella seals (.510 lift cam)?
Will the combination of howards lifters work with the base circle of the comp cam? Can't find the base circle numbers printed to compare the two.
All help is appreciated. Already searched.
IMO, I wouldn't run a cam, hydro roller or flat in a 335 with the same profiles on each lobe. Always favor more lift and duration on the exhaust.
You should always run the mfgr's recommended spring at the heights and pressures they recommend.
IMO, I would just save my money and figure out why it went bad in the first place. You are going to have a lot of time and money tied up in something that isn't necessary.
I decided to go with the comp 260h cam, 924 valve springs, comp retainers & locks, howards link bar roller lifters.
Will measure for push rods when I get the rest of the parts in. And let you all know how it works.
Does anyone know if howards lifters will work with a reduced base circle cam?
Started taking the engine apart. Yep, one push rod was loose as I had thought. Bad news was it was because the rocker arm was loose. Yep I feel like a dip **** but when I don't even have time to work on the truck I have to make some assumptions sometimes.
Good news is there's no metal in the oil.
Well I already got all the parts so I'm going on with the hydraulic roller set up.
Heads are at machine shop getting positive seals, springs set up for cam, and .025 milled off them.
Comp 270H is on its way. Talked to TMI and am ordering some Lunati Link Bar lifters and Scorpian roller rockers.
Will update with some pics or video when its done.
Holley 670 CFM Truck Avenger
Top hat K&N
1" 4 Hole Carb Spacer
4BL Edelbrock Intake
Summit Racing HEI Dizzy
DUI Livewires
Flowtech Ceramic Coated headers
2 1/4" True Duals & Flowmasters
Shortblock is 17,000 original mile from grandma's T-bird (overhauled it)
New Melling Oil Pump
Robert Shaw Thermo
Valvetrain
Comp Cams Double Roller Timing Chain (cam is set straing up)
Comp 270hr cam
Roller Rockers
Heads (rebuilt)
.025" shaved
3 angle valve job
positive seals
set up for .566 lift
comp 921 springs
steel retainers
New fuel pump, water pump, fan clutch, fuel filters, fuel lines and i got a tuff stuff 140A alt coming for it too.
Any ideas on how much power I could expect from this thing? Got a buddy who thinks his 1/2 chevy is gonna pull me... HA.
I should have ran some thinner head gaskets to tighten the quench and pick up a bit more compression. I just couldn't justify the cost of the gaskets for a build this mild. I see i can borrom a magnetic base from me buddy and measure where the pistons sitting at.
I'd love 340HP. I'm gonna pick up some holley parts and get the carb dialed in once she is up and running. There was def room for improvement on it before i tore it down for the new valve train.
My truck is a long bed regular cab. Fairly new 36" iroks. 4.10 gears. No lockers tho.
His truck is a 06 crew cab chevy, 5.3, headers, intake chip, 4.56 gears, tru track rear, 35" toyos on 20's which are about 50% tread. We're gonna do it on concrete, I don't want none of that dirt action since he has that locker.
Anyways he hooked up to a new dodge 1/2 ton a month or two ago and he started hopping and f'ed all kinds of stuff up. Twisted his aluminum driveshaft like a pretzel, ruined his lift blocks and spring perches, transfercase was iffy and he broke a front cv. It was a good deal. I lauged my *** off. Poor lil chevy. I told him I'm the undertaker and I'll be here to finish it off when i roll mine out of the shop. Guess if I break my **** I can always pull my axles out of whitey for a few weeks
Good sounding idle, great throttle response and pretty good power. I can def beleive this thing has 320 HP. It pulls pretty good and its got a nice broad curve from the feel of it. Great throttle response, cruises really well. I didnt figure the fuel milage but it didn't seem to bad. Drove it all around town yesterday and almost 70 miles back to school today. Ran like a champ.
I've got a 670 truck avenger on this thing. Alot of ppl bitch about these. Mine worked great. All I had to do was get the timing straight and adjust the idle screws. Runs like a top, if there is more to be had I'd be susprised, but not totally opposed to it
While I had it in the shop I replaced the window weather strip and added dynamat to the floor. Wow, I could
now while driving this thing. Love it.The ole C6 started to slip on me tho.
Only sometimes, well see how long it lasts before it totally takes a dump on me hahaha. I've got a real good condition 2wd tranny. Is it very hard to take make this trans work in my truck using the rear shaft from my truck? I would believe I could tackle a rebuild myself but have a good friend with alot of experience in them.The moral of the story is. $4200 later, I am loving the truck more and more.
