1" coil spacer I ordered ?
Old Feb 28, 2012 | 10:06 PM
Boss08v10's Avatar
Boss08v10
I ordered these from summit racing and was wondering if anyone has used them and if they will work prior to tearing into the job. We have some new coils to put in and hope these will give us another inch or so. Is there a reason they will not work or a better product I should use instead.
Thanks
they are part number sps-1728
Old Feb 29, 2012 | 03:14 AM
TexasGuy001's Avatar
TexasGuy001
I don't think you'll be able to get it aligned with more than 2 inches of lift. Besides that, wont the front be higher than the back with that spacer. I'm also not sure it will fit the spring. Well I guess we need to know what springs you got. Are they stock, leveling, or replacement F250 springs?
Old Feb 29, 2012 | 12:40 PM
Boss08v10's Avatar
Boss08v10
Stock replacement springs, the back is way high since the new leafs went in. I my just buy the cc844's and be done with it but these were cheap and I already had the new stock coils. I think maybe I am making more complex then I need to be.
I had never seen any of these before and the summit picture just showed a generic pic. Having not put new coils in a TTB front before I was wondering if anyone had seen or used this type before.
Old Feb 29, 2012 | 12:52 PM
Midnite1987's Avatar
Midnite1987
I used the 2" ones that sit under the spring and comes with a stud extender
Old Feb 29, 2012 | 04:07 PM
Boss08v10's Avatar
Boss08v10
Do you have a part number and what brand?
Old Mar 1, 2012 | 01:17 AM
TexasGuy001
If you want to level the front, get either Superlift or BDS leveling coils or some Moog CC844 springs which are replacement F250 springs.
I just do not trust spacers.
Old Mar 1, 2012 | 05:36 AM
xxshine's Avatar
xxshine
Remember to get it aligned. Any time the ride height changes, so does the camber.
Old Mar 2, 2012 | 02:36 AM
TexasGuy001
You'll definitely have to get it aligned and probably have to get the camber bushings.
Old Mar 2, 2012 | 11:14 AM
Boss08v10's Avatar
Boss08v10
I am returning the spacers and the stock springs for a pair of cc844's and will be getting an alignment after that for sure.
Old Mar 2, 2012 | 11:18 AM
Midnite1987
I used the eBay spacers
Old Mar 2, 2012 | 11:29 AM
minnesotafisherman's Avatar
minnesotafisherman
That's the way to do it!
After I installed the 844's in my truck, I noticed a HUGE decrease in body roll around corners, etc.
Old Mar 2, 2012 | 12:36 PM
ravens fan's Avatar
ravens fan
i too got new stock size leaf springs and it jacked my rear end way up..... and i have seen too many people on here with the moogs that barely lifted the front at all i guess it depends how much your old springs were wore out.......either way i got the 2 inch spacers so i could get a true 2 inches of lift
Old Mar 2, 2012 | 01:08 PM
Fungus232's Avatar
Fungus232
X2! Lifted my frontend 1.5" exactly. Only been driving on them since Tues and I love'em.
Measurement from ground to highest part of wheel opening on fenders (32x 11.50x 15 tires),
Before:
Front = 34.25"
Rear = 36"
After:
Front = 35.75"
Rear = 36"
Old Mar 2, 2012 | 03:23 PM
Boss08v10's Avatar
Boss08v10
Hey guys thanks for the all the feed back. The plan now is to put in the cc844's and see where we sit. If we still do not like the rake of the truck I think we are thinking we may pull one leaf out. I also ordered some pro comp ES 1000 front shocks from JC whitney, $58 bucks for the pair free shipping right now.
On the alinement for the front, I stopped and talked to the local frame shop guy I know pretty well to get an idea on cost for the TTB job. Four wheel alinement is $100 complete, nothing extra for cams or nothing. The way I have been reading around here it sounded like I would need to spend a whole bunch more then that. So my advice is ask around and find the experts. How truck is pretty rusted and old and he said it will not be an issue and in fact about a 45 minute job, pie of cake.
drwecki
24
Nov 18, 2017 04:23 AM
indebt
16
Mar 10, 2009 05:39 PM
DS02F250
Jan 30, 2005 09:46 AM
truckman79
Sep 17, 2003 03:18 AM
Quadiquizm
Dec 14, 2002 09:55 PM
