Question on T.S. performance
Old Mar 3, 2012 | 09:17 PM
the78ranger's Avatar
the78ranger
ok, well I built a leak detector, and no leaks anywhere. So I decided to unplug the waste gate and see if it raised boost numbers at all and no 10lbs max. So I decided to load my friends 78 c10 on a trailer and see what boost numbers i could come up with. and STILL 10 LBS. wtf!!!!! same boost numbers as unloaded. But I forgot to mention that my EBPV valve has been unhooked, so I just pulled it off and am deleting it today/tom. I think this is the only other possible thing it could be..... The thing is unhooked due to the fact the sensor was broken during turbo removal for upipe gasket replacement. And i think its closing from the exhaust gas.
Old Mar 4, 2012 | 08:57 AM
the78ranger
Anyone? If its not the exhaust valve closing I have no clue what the problem can be....
Old Mar 4, 2012 | 09:58 AM
JT250's Avatar
JT250
Did you check of? I never saw the results. Usually when it is closed it feels very sluggish.
Old Mar 4, 2012 | 02:46 PM
the78ranger
YES!!!!! I just deleted the ebpv in the exhaust side of the turbo. I am now pushing 22lbs in the 70 tune. I have never actualy felt this trucks full potential until now hahahah. When I bought it, it had both up pipes leaking really bad and the part were the up pipes come to the turbo had an 1/8 inch gap. well when I fixed that, I broke the sensor for the exbp and thought the exhaust pressure would hold the flap open. well I was wrong big time and I'm That much more in love with this truck. Thanks everyone for your help!@@@@@
Old Mar 4, 2012 | 07:41 PM
cj45lc's Avatar
cj45lc
Good deal, I'm glad you got it figured out
I bet your egt #'s look a lot better with the exhaust having somewhere to go
Old Mar 4, 2012 | 08:14 PM
JonathanN's Avatar
JonathanN
I could do 20 in stock... with my tunes, I throw an SES. But that's with my wastegate rigged differently. What I did was remove that "contraption" that's bolted to the front of the spider and then I set the wastegate to start opening at 20psi. It worked great in stock, but now I throw an SES regardless with my tunes. I need a boost fooler... that and I'd love to have a non-wastegated housing.
Old Mar 5, 2012 | 08:42 AM
JT250's Avatar
JT250
I don't know if u want a non wastegate housing w a stock Turbo. U need yo be able to keep boost under 25the for the Turbo to survive.
Old Mar 5, 2012 | 10:59 AM
JonathanN's Avatar
JonathanN
I know... I haven't been able to make that much. As for the housing, that would be on a 38R if I ever got one.
Old Mar 5, 2012 | 02:22 PM
MR5x5's Avatar
MR5x5
22 pounds still sounds low...? Anybody know if his chip disables the over boost protection?
Old Mar 5, 2012 | 02:33 PM
WA_PSD's Avatar
WA_PSD
I pull around 23PSI WOT in 80E. I pull about 16.5 stock.
Old Mar 5, 2012 | 02:37 PM
the78ranger
I hit 22 lbs in my 70 tune and it starts to surge at that point. I think thats def good enough for now on the stock turbo
Old Mar 5, 2012 | 02:53 PM
JT250's Avatar
JT250
22 sounds safe to me you could get more by adjusting the waste gate but any benefit wud be nominal. I had mine up to 30 by adjusting the wastegateon stock Turbo....had to back it off
Headviking
Sep 12, 2010 10:11 PM
rhodester
13
May 6, 2008 07:14 PM
jhorton
31
Feb 25, 2008 01:46 PM
1960Airstream
May 25, 2004 06:02 PM
jharvey3
Sep 22, 2003 05:19 PM
