6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
leakin
Old Feb 28, 2012 | 06:00 PM
blacksmoker08's Avatar
blacksmoker08
leakin
Hey. I got a 08 f250 6.4 diesel there is antifreeze leakin out pretty bad some where ontop of where the bottom rad hose meets the motor. I was just wonderin if u guys had any ideas ? Thanks
Old Feb 28, 2012 | 06:08 PM
PA-Mark's Avatar
PA-Mark
This may be under warentee still, head to the dealer and ask quick! Like a bunny!
Old Feb 28, 2012 | 09:14 PM
powerstroke72's Avatar
powerstroke72
Moved to the 6.4L Power Stroke Diesel forum.
Old Feb 28, 2012 | 10:28 PM
Tom's Avatar
Tom
Hi Blacksmoker80, welcome to FTE!
Sorry to hear that you have a problem though; radiator hose problems aren't that uncommon to hear about. How many miles are on your truck? There's a small chance you could be under warranty, otherwise it'll be a couple hundred dollars to fix at your local dealer.
Old Feb 29, 2012 | 06:25 AM
senix's Avatar
senix
Sounds like the radiator hose o-rings failed.
They have updated the hoses to be a double o-ring now.
If you are still under your 36/36 then it would be covered but I kind of think not.
those hoses are pricey.
Old Feb 29, 2012 | 06:53 PM
galaxie641's Avatar
galaxie641
Need to take note of exactly where they are leaking, have them show you. Makes all the difference on if it is warranted or not. Either end you have a good chance, if it is the middle you are SOL and will run a good $500 and up for the new hoses installed.
Old Feb 29, 2012 | 06:58 PM
blacksmoker08
I don't think its the hose its a little higher up fron where the hose meets the motor
Old Mar 1, 2012 | 01:48 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Sounds like a leaking thermostat housing.
Old Mar 1, 2012 | 02:08 PM
blacksmoker08
Oh I hope so illl keep u guys posted
Wes64052
Dec 12, 2017 06:43 AM
TennesseeGuy
Mar 22, 2012 07:31 PM
Stillhumpnit
Jan 25, 2012 06:33 PM
bh56
May 19, 2011 01:02 PM
gameboynws
Dec 5, 2004 11:09 PM
