Engine Swap
Old Feb 27, 2012 | 07:58 AM
cray0971's Avatar
cray0971
Engine Swap
Ok I need some help making the correct move here.... My daughter has a 1978 F-100 w/a 302 and launched a rod....The engine is toast. . Here's my question...I am on a very tight budget...Should I get a long block out of a donor truck (same model about $300.00) Or I have found a mid 90's explorer with the H.O.302 for 400.00. I will convert it over to carb. What else would have to be changed. Will the oil pan be ok and what about the cam and dist., will the ones off the HO be ok with a carb??? Any insight ya'll can give???
Old Feb 27, 2012 | 08:20 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Well the long block with all your outer parts would be the quickest swap as I see it.
2wd eng oil pan is a front sump and 4wd oil pan is rear sump. To change it you need a different pan and pick up tube.
Can you at least get a "run warranty" on the 300 dollar long block? The HO 302 is out of a ? Motor mounts, external eng pieces compatibility? Converting to carb and figuring out the rest might eat up more time.....
Old Feb 27, 2012 | 08:25 AM
DeepRoots's Avatar
DeepRoots
If you are in South Ga north florida, come on over I've got a 302/fmx with edelbrock intake, drop in for cheap. I just want my floorspace back :-)
Old Feb 27, 2012 | 08:39 AM
cray0971's Avatar
cray0971
Sorry DR Im near Dallas TX
Old Feb 27, 2012 | 08:44 AM
cray0971's Avatar
cray0971
sorry DR im in Dallas TX
cray0971
Feb 28, 2012 11:43 AM
finneys98xj
Jan 8, 2011 04:27 PM
flareside_thunder
1978 - 1996 Big Bronco
Oct 21, 2007 10:10 AM
cam-rach
Dec 23, 2004 04:53 PM
pinegreen
Nov 15, 2000 08:52 AM
