Sponsored by: Real Truck
Door ajar light
Old Mar 5, 2012 | 08:17 AM
deck60's Avatar
deck60
I agree these switches are a nightmare I am guessing it is elimination
drivers door if you leave key in and door chime goes off when you open door and shuts off when it closes then it is ok
then the rest is elimination from what I have concluded is that each switch is a 2 wire switch and when the door is closed it makes continuity so if you put a jumper across it then you should be able to find the bad switch
Old Mar 5, 2012 | 03:13 PM
afonda's Avatar
afonda
ummmm
So you are stating to unplug the 2 wire harness and use a solid wire to connect the two prongs in the harness? Good idea... I will see if it works.
Old Mar 5, 2012 | 03:22 PM
deck60's Avatar
deck60
yes that should fool it and make it think the switch is made
Old Mar 6, 2012 | 11:49 AM
afonda's Avatar
afonda
so...
This means that when the little button is depressed on the sensor it is creating a circuit.
I was thinking that the when depressed it was breaking the circuit.
Knowing the answer to this, will make all the difference in how we test the circuit.
Old Mar 8, 2012 | 09:31 AM
afonda's Avatar
afonda
bump...
can anyone please comment...
Old Mar 9, 2012 | 06:28 PM
deck60's Avatar
deck60
I would like to know this myself it when the door is shut is the switch open or closed
Old Mar 10, 2012 | 03:41 AM
JKBrad's Avatar
JKBrad
The switch is depressed. So, if they work like most push button switches, it is probably open when closed.
The switch plugs into the harness. It my be that simply unplugging the switch will disable it.
Either way, the switch cam easily be bypassed. The only drawback I see, is that the lights wont come on when the door is opened.
The switch is inside the door, attached to the bottom of the latch assembly.
Old Mar 10, 2012 | 08:50 AM
deck60's Avatar
deck60
I have been having trouble with my wife's escape and also our f250 at work if the switches are the same on the escape as our trucks then it is a n/o contact that when shut becomes a closed contact so jumping the switch out complete the circuit so unplugging it would do nothing
does any one have a old door switch ohm it out open and closed and let us know
Old Mar 10, 2012 | 10:34 AM
jh818's Avatar
jh818
My guess would be that when the door is shut, it creates a closed circuit. Over time, dirt, grime, and maybe corrosion of the metal contacts builds up and it loses conductivity. Spraying WD40 to clean off the contacts so it makes a closed circuit helps on a short term basis.
I could be wrong....
I can't see how it can be an open circuit when you shut the door. If it is, then I can see the dome light never coming on when gummed up rather than staying on all the time. Picture it like your refrigerator light switch.
Poor design IMHO. Maybe it is required to be in a closed circuit for the time delay...to send a signal to the relay?
Old Jun 14, 2012 | 04:05 PM
clintusaf's Avatar
clintusaf
Mine is doing the same thing. I'll have to check it when i have some time and see if I can narrow down which door it is.
Old Jun 15, 2012 | 12:33 AM
JKBrad's Avatar
JKBrad
Mine started doing it again. Time to replace the little switch on the latch.
cabldawg
May 31, 2022 05:08 PM
JTATMAN
Sep 11, 2005 09:54 AM
dannunz
Jul 31, 2005 06:13 PM
hdman6
Feb 3, 2005 02:59 PM
Ultramagdan
1997 - 2003 F150
Dec 4, 2002 04:06 PM
