Sponsored by: Real Truck
tire pressure
Old Jun 14, 2012 | 07:10 PM
FORDf250XLT's Avatar
FORDf250XLT
tire pressure
Does anybody know what psi the stock tires on an 06 f250 is? Thanks
Old Jun 14, 2012 | 07:19 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
There was a reference sticker on the b-pillar below the VIN sticker, but sometimes it disappears. 265/70R17s were 75psi on each corner for my truck. 275/65R20s were 65psi for my dad's, and that label lists 65psi for a 275/70R18 spare that matches the factory 18" tire size. To be honest you can run up to the max sidewall pressure without any issues, but some people complain that the truck rides too truck-like when you do that You can chalk test the tires (run chalk across the tire, drive a few dozen feet, it should wear off evenly) to reduce the pressure below the max/recommended pressure to make sure the tires are wearing evenly, the rears ofter need to be dropped below the front because of the lack of weight in an empty bed.
Be careful and check the tire sidewalls, if the tires have ever been replaced the new ones might not match the load rating of the original equipment, and you should never exceed the maximum pressure on the tire sidewall, no matter what any sticker or manual on the truck says.
Old Jun 15, 2012 | 06:42 AM
Quad Racer's Avatar
Quad Racer
Yeah do a chalk test and run the pressure that makes the tire most happy. For me it was 70 in the fronts and 65 in the rear (unloaded). Dont run more than the sidewall of the tire or less than the door jamb tag.
bigredtruckmi
Oct 22, 2008 03:37 PM
therigwelder
Oct 17, 2006 08:41 PM
Peter Nikols
1997 - 2003 F150
May 21, 2004 02:05 PM
christaylor
Jan 29, 2004 12:15 PM
TexasGuy001
Nov 19, 2002 08:22 AM
