help with codes
Old Feb 26, 2012 | 02:35 PM
F350Kid238's Avatar
F350Kid238
help with codes
pulled some codes today i just want some advice on why theyre coming up and how to fix it. first code 558-EGR valve regulator solenoid circuit fault ,113- intake air charge temperature sensor above maximum voltage/-40 indicated, 211- profile ignition pickup (pip) circuit fault. any help would be appreciated
Old Feb 26, 2012 | 05:57 PM
F350Kid238's Avatar
F350Kid238
.....anyone?
Old Feb 26, 2012 | 06:47 PM
subford's Avatar
subford
The 113 may mean that the engine was not at operating temp when the codes were read.
The 211 may mean the PIP sensor is going bad.
The 558 may mean you have a vacuum leak around the three solenoids by the Ignition coil. Or a wiring problem to the EGR (EVR) solenoid.
Going by your def as I did not look the codes up.
Old Feb 27, 2012 | 12:01 AM
rla2005's Avatar
rla2005
I have found code 558 is usually triggered by an open or disconnected EGR Vacuum Regulator (EVR).
For reference of where the EVR is located on a 5.0/5.8L engine:
Ro11y
Feb 9, 2024 02:36 PM
bigedusa
23
Aug 31, 2012 09:46 PM
bobbyt89
Apr 13, 2010 06:53 AM
marragtop
Mar 18, 2008 09:54 AM
Daniel.r
Mar 19, 2004 06:09 PM
