code P0443
Old May 7, 2012 | 08:31 PM
  #31
IJRoorda's Avatar
IJRoorda
I plugged in my salvage yard PCM tonight and sure enough, no more P0443 and no more flashing TCIL, so I am betting the P0713 is gone too. A replacement PCM seems to be the cure for this particular ailment.
Thanks for the help, rla2005 (and subford - the wiring diagrams were helpful).
Old May 8, 2012 | 10:20 AM
  #32
rla2005's Avatar
rla2005
Thanks for reporting back with the resolution! Very odd problem. I'll keep this one in my notes for sure.
Old May 25, 2012 | 12:48 PM
  #33
polarisman729's Avatar
polarisman729
P0443 code
Hey guys, I was reading your posts on the subject. I just purchased a 1996 f-150 with the 5.8l and I have the same symptoms. The CEL is on with a P0443 and alsot the od light flashes. The od light will flash when first started and the go out once the truck is warm. I checked voltage at the VMV and have 12v key on. The resistance for the VMV was .5 ohms. Also, when I unplug the connector at the VMV, the od light will stop flashing and starts as soon as the connector is plugged in. I was told that there is a code stored for the transmission temp sensor in the solenoid pack. I wonder if the transmission is a byproduct of the P0443 or if I do have 2 separate issues or if my PCM is faulty and giving the false codes. I might try and replace the VMV to see if that makes a difference.
Old May 25, 2012 | 06:09 PM
  #34
rla2005's Avatar
rla2005
.5 ohms is a dead short, replacing the VMV is probably the best solution if your test values are correct.
Old Nov 2, 2014 | 01:50 PM
  #35
A&P Mech's Avatar
A&P Mech
Hello everybody, thanks to this great forum, I just solved the same problem with my 96 F350 4X4 XLT 7.5L by replacing the PCM with a re-man unit from Autozone. My post can be found here: https://www.ford-trucks.com/forums/1...l#post14770439 I hope this helps anybody else out there with this same perplexing problem.
RusPro
4 Cylinder Engines
Feb 11, 2017 10:00 PM
dvlsmstr
1997 - 2003 F150
Feb 2, 2014 06:57 AM
pablocruz69
Aug 13, 2010 12:50 PM
ol'ruby
Aug 24, 2007 09:49 PM
shagz
1983 - 2012 Ranger & B-Series
Dec 8, 2000 12:46 PM
