Clutch Equalizer '49
Old Feb 24, 2012 | 07:42 AM
john fin's Avatar
john fin
How do you replace the spring and bearing halves in the equalizer shaft?
Old Feb 24, 2012 | 08:49 AM
mtflat's Avatar
mtflat
Disconnect the linkage, pull the pin out of the clutch side and swing it clear.
Old Feb 24, 2012 | 09:01 AM
john fin's Avatar
john fin
parts
That does not make any sense to me on how to replace the internal parts of the clutch shaft.
Old Feb 24, 2012 | 09:11 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Are you talking about the bushings in the half-bell on the trans, or what? Not clear. MT's description is correct for the two half-bushings in the DS end of the "Z-bar" or equalizer shaft.
Old Feb 24, 2012 | 10:21 AM
john fin's Avatar
john fin
parts
I have the whole asssembled part out with the ball/mounting plate attached. Are you saying I need it mounted in the truck and move the shaft to one side, prying the ball out of the socket?
Old Feb 24, 2012 | 01:19 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Just pull the shaft off the ball, there's nothing holding it in.
Old Feb 24, 2012 | 07:09 PM
john fin's Avatar
john fin
parts
Mine wont pull apart for some reason. It pivots ok but wont come apart. I guess I need to put it in a vise and pull it apart.
Old Feb 24, 2012 | 07:36 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Try pivoting it as far to one side as possible. Look at the pic below to see how the bushings fit over the ball (ignore the junk the the right).
Old Feb 24, 2012 | 11:03 PM
jmadsen's Avatar
jmadsen
Wow, I've never seen one of those shafts that didn't just fall off the ball and the brass bushings fall out in pieces.
Old Feb 25, 2012 | 08:49 AM
ALBUQ F-1's Avatar
ALBUQ F-1
LOL, those pieces to the right of the new bushings in my pic are what was left of one of the bushings, and a hose clamp the PO stuck in there to take up the slack! Yeah, it came apart "easy"! (It actually worked pretty good!)
Old Feb 27, 2012 | 12:03 PM
john fin's Avatar
john fin
Bushings
I noticed that the new bearings sold are plastic, are they junk?
Ford Pickup Truck Clutch Equalizer Bushings - MAC's Antique Auto Parts
Old Feb 27, 2012 | 12:33 PM
jmadsen's Avatar
jmadsen
I got bronze. or brass? forgot where though.
Old Feb 27, 2012 | 01:37 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Plastic may well be an improvement. You can see what's left of the bronze in my pic. How often do people grease these? Not a lot of force involved just dirt and neglect.
Old Feb 27, 2012 | 09:46 PM
mtflat's Avatar
mtflat
Similar bushings (nylon or plastic) were used by Ford on my brand new '77 F100 way back when.
Old Feb 29, 2012 | 07:35 AM
john fin's Avatar
john fin
equilizer
Ok farmer john did it to me again. Found out why it was tought to get the ball out: the farmer used a steel sleeve to hold the ball in. I am going to have a hell of a time removing the sleeve. If I use the plastic sleeve do I still need to grease it and what keeps the the sleeve from turning?
Cougar54
24
Jun 5, 2025 06:31 PM
easyrider47
Oct 20, 2014 11:01 AM
Ryan Sigman
Mar 23, 2013 07:55 PM
crazyscott
Apr 23, 2008 09:25 AM
lerry
Jun 24, 2003 10:31 AM
