Injection pump
Old Feb 23, 2012 | 11:02 PM
diablodude64's Avatar
diablodude64
Injection pump
Okay so after tracking down my leaks and then removing and reinstalling the fuel lines on the injection pump twice, my leak is still there right on the same bottom fuel line.
It isn't as bad as it was, but that SOB is tight now and still leaking... There is a little bit of play on the line so is the actual mating surface messed up or out of tolerance?
Where can I get a new one?
Thanks, Kyle
Old Feb 24, 2012 | 02:05 AM
85chugalug6.9's Avatar
85chugalug6.9
Mine leaks in the same place...I too would like to know how to resolve this leak...
Old Feb 24, 2012 | 03:03 AM
IDI guy's Avatar
IDI guy
go to the junkyard or check with your local diesel injection shop many of them can make new lines.
Old Feb 24, 2012 | 10:23 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
You can buy new lines from Mid West Fuel Injection now calling themselves "TheDieselStore.Com" ...
Or grab em from a junk yard.
-Enjoy
fh : )_~
Old Feb 24, 2012 | 11:54 AM
diablodude64
Well none of the yards around here have anything 6.9 related...
Anyone in the medford, Oregon area have any?
Old Feb 24, 2012 | 02:27 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
remember when replacing ip lines,to use either a full set of 6.9 or a full set of 7.3l or your timing will be off on the cylinder(s) you replaced the incorrect length line with.
Old Feb 24, 2012 | 05:13 PM
eatont9999's Avatar
eatont9999
The lines are a different length on 6.9 and 7.3s?
Old Feb 24, 2012 | 06:24 PM
tecgod13's Avatar
tecgod13
The number 1 line is different (#4 on vans?) because of the timing adapter on the 7.3's.
I too thought the rest were the same though?
Old Feb 24, 2012 | 09:59 PM
diablodude64
I just needed the number 2. Runs amazing with no misfire at all.
menmy02x
Feb 23, 2009 08:46 PM
tbm3fan
Oct 3, 2008 05:55 PM
chewyjackson
Apr 4, 2007 12:00 AM
ram2miller
Dec 19, 2006 11:08 PM
Bigredcrew
Nov 9, 2006 10:20 PM
