Fuel line ?
Old Feb 23, 2009 | 07:48 PM
menmy02x's Avatar
menmy02x
Fuel line ?
Can you cut the metal lines next to the fuel canister at the front of the head and replace them in rubber? Been fighting a fuel leak and thought i had it, seems it has me. Replaced all i could on the fuel canister and it seems dry. Looked tonite and the valley right under the tank to pump and return line are getting wet first. The motor gets wet next to the canister and under the lines like one is seeping.
Thanks again Vince
Old Feb 23, 2009 | 08:26 PM
jimwilsonmasonry's Avatar
jimwilsonmasonry
could be your fuel pump there is a tiny weephole on the bottom of the fuel pump that will leak when it goes bad
Old Feb 23, 2009 | 08:40 PM
menmy02x's Avatar
menmy02x
the leak is not that low. it's next to the canister where the base meets the valley on the drivers side. like a metal line is leaking.
Old Feb 23, 2009 | 08:46 PM
jimwilsonmasonry
thats about where the weaphole is it under one of the arms of the lift pump
