Stalling issue
Old Feb 22, 2012 | 01:49 PM
highguy2012's Avatar
highguy2012
Stalling issue
Hi!
Just wondering about an odd stalling problem I have,
1977 Ford F250 4X4, 300ci...
Starts runs and turns great however, every so often when turning the wheel even slightly (changing lanes) the truck will start missing and stall. Much more noticeable in a parking lot while parking....
Truck is not in gear while this is occurring, the clutch is usually depressed.
Has happened on both left and right turns.
Loads: radio was on, wipers on slow speed, no heat or a/c, no lights.
Thanks for any ideas.
Old Feb 22, 2012 | 06:00 PM
wyckedcombo17's Avatar
wyckedcombo17
Kind of WAG, but I might pressure test your power steering system to see if you have a restriction. This would make the pump work harder, and in a situation when you don't have the throttle open (clutch depressed I'm assuming you're not on the gas) the load could be too much and bog the motor down. I've never heard of something like that before, but I don't think its impossible.
FirecrackerKTM
Jan 22, 2012 02:43 PM
SailCO26
25
Jun 4, 2010 09:41 AM
f30199191
Mar 30, 2010 05:56 PM
straightexhaust
Dec 11, 2006 09:56 PM
1-4-ford
Feb 23, 2003 08:22 AM
